Need help ASAP!
Old Aug 31, 2004 | 08:28 AM
98JDM_Type_R's Avatar
Default Need help ASAP!
Need to hook up my crank angle sensor, but don't know how.
95 OBD1 GSR swap in a 00 EK
I have a 00 SI harness, but don't know how to hook it up to the distributor.
TIA
Old Aug 31, 2004 | 10:06 AM
Default Re: Need help ASAP! (98JDM_Type_R)
BUMP E D BUMP
Old Aug 31, 2004 | 10:10 AM
EE_Chris's Avatar
Sure you got your terminology right?
The TDC, CYL, and CKP sensors are built into the distributor.
The CKF (crank fluctuation) sensor, mounted down by the oil pump, only needs to get hooked up if you're running an ECU that is looking for it.
Old Aug 31, 2004 | 10:13 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Need help ASAP! (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote"> only needs to get hooked up if you're running an ECU that is looking for it.</TD></TR></TABLE>
i belive OBD2 ECU's.
eveything else put crank angle sensors in the dizzy.
Old Aug 31, 2004 | 10:50 AM
Default Re: Need help ASAP! (Built B16A)
Okay, I wired up my distributor OBD1 distributor to work w/ my 00 Si harness, but I ran into one problem
On the distributor, there are two clips:
1 Clip w/ 7 wires (I already have it all wired up)
1 Clip w/ 2 wires
The clip w/ 2 wire, I only have one wire on my harness (black). What do I do w/ about the blue wire on the distributor?
Old Aug 31, 2004 | 10:53 AM
These are the two wires I'm talking about.
I only have the black/yellow on my harness. I don't have the blue.
Old Aug 31, 2004 | 11:52 AM
hatchi's Avatar
on the 00 si harness i believe the crank angle sensor is on the harness by the crank pulley
tanner_pimp101
Apr 1, 2014 08:11 PM
hondaaccordf23
Nov 18, 2012 08:56 PM
Y2KCivicSiR
Nov 21, 2007 03:26 PM
civicEXtreme
Jun 14, 2006 03:17 PM
89 CRX SI
27
Jan 20, 2003 04:12 PM
