Hytech exhaust???
Old Aug 31, 2004 | 07:28 AM
hype r 555's Avatar
Default Hytech exhaust???
Just Installed Hytech exhaust on my 98' ITR.....Everything went good except for the fact that the exhaust is resting against and putting pressure on my shift rod. One of the spring bolts is bent (the spring part not the bolt) because it's not long enough and is extremely tight. I'm going to replace both spring bolts with longer ones so they are straight and and snug, not bending tight. Is there anything else i should do as well to correct the problem....Did anybody else have this problem or others with this exhaust????? thanx
Old Aug 31, 2004 | 08:04 AM
hype r 555's Avatar
Default Re: Hytech exhaust??? (bb4lude)
damn nobody??? I should probably tell you i'm running the comptech race header, and full hytech exhaust w/ test pipe....anybody...
Old Aug 31, 2004 | 08:18 AM
Big Phat R's Avatar
The custom jobs always require some fiddling - sounds like you are on the right path.
Old Aug 31, 2004 | 11:58 AM
IGGY's Avatar
Default Re: Hytech exhaust??? (Big Phat R)
I always thought custom and more expensive would fit better.
Old Aug 31, 2004 | 12:07 PM
T.A.M.'s Avatar
I would say some normal tweeking to get it correct isent out of the ordinary
Old Aug 31, 2004 | 01:20 PM
IGGY's Avatar
Default Re: (T.A.M.)
Well T.A.M. enlighten on what normal tweeking would be.
Old Aug 31, 2004 | 01:27 PM
Pondus's Avatar
Default Re: (IGGY)
Well i had to use a hammer on the heatshields to keep my Hytech exhaust from rattling, but that was all really, fitment was very good. But i also have a Hytech header, don't know if the fact that he has a Comptech header makes a difference.
Old Aug 31, 2004 | 01:30 PM
Big Phat R's Avatar
Default Re: Hytech exhaust??? (IGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">I always thought custom and more expensive would fit better.</TD></TR></TABLE>
When you use bigger piping like the true 2.5" systems - you have a lot less clearance.
So some tweaking is always necessary.
BB4Lude: try adjusting the hangers as well
jkalex05
Aug 8, 2009 02:09 PM
NegativeXero
Nov 23, 2006 04:51 PM
Floored
Jul 17, 2006 07:37 AM
94AccordCoupe
18
Feb 12, 2004 11:36 AM
civic-cpe
Sep 15, 2002 07:59 AM
