CRVTEC / LSVTEC Turbo Oil Tap questions answered *searched*
Old Aug 31, 2004 | 07:12 AM
ARIZONA's Avatar
Default CRVTEC / LSVTEC Turbo Oil Tap questions answered *searched*
I couldn't find anything in the archives so I figured I would start a new thread that would get some answers and be easily searched for future reference...
Anyway, I am in the process of installing my T3/T4 onto my CRVTEC (b20b/pr3) and have finished everything all the way up to the oil feed.
Now, my question is... If I split my tap at the back of the block with a 4-way or similar ( I just don't want more than 2 fittings protruding from the block, that's just nasty and trouble waiting to happen...) and am feeding the head, sender, and the turbine... am I going to be running oil pressure thin?
Any suggestions on size of line I should switch to... basically is it worse for it to be too small, or obviously too big but I guess I just want to know what the optimal size would be...
Thanks...
Old Aug 31, 2004 | 07:20 AM
-Trinitron-'s Avatar
One of the things you can do is to put an oil pressure reducer before the turbo. It will keep the turbo from seeing too much pressure, as well as keep some of the pressure in the motor. Most people just run standard 1/8" NPT braided steel lines.
Old Aug 31, 2004 | 07:23 AM
ARIZONA's Avatar
Default Re: (-TRINiTRON-)
okay, that's new to me.. so how do you determine how much oil supply a turbine needs ya know, like how do I pick a reducer?
Old Aug 31, 2004 | 07:31 AM
Default Re: (ARIZONA)
Generally the most oil pressure a turbo wants to see is between 45-60 psi. Oil pressure reducers are usually only 1 size. The one that ATP Turbo sells has a .060" opening.
Old Aug 31, 2004 | 07:36 AM
wade's Avatar
arizona, check out this link and see how i rigged up a oil line for my turbo, head and oil gauge...
http://community.webshots.com/user/tiretearing2
Old Aug 31, 2004 | 07:41 AM
ARIZONA's Avatar
Default Re: (wade)
Wade, thanks for the link... I have all the fittings and started doing that last night, then decided to find another way as I just don't like the idea of an assembly sticking out that far... all it takes is me slipping changing an oil filter or something and risking stripping that tap out...
Old Aug 31, 2004 | 07:44 AM
wade's Avatar
mine has been that way for roughly 15K miles and its fine. i have no regrets..my oil press is great too
Old Aug 31, 2004 | 08:05 AM
Default Re: (wade)
You arent supposed to put brass fittings straight in the block like that. The vibration will cause stress fractures and it will eventually snap off. You should run a line off the block and tee of everything from there. Like this, only you will have 1 more tee for the turbo.
Done properly, you would attatch the fittings to the firewall for support and vibration insulation.
Old Aug 31, 2004 | 08:11 AM
Syner-G-Racing LLC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote"> You arent supposed to put brass fittings straight in the block like that. The vibration will cause stress fractures and it will eventually snap off. You should run a line off the block and tee of everything from there. Like this, only you will have 1 more tee for the turbo.
Done properly, you would attatch the fittings to the firewall for support and vibration insulation.</TD></TR></TABLE>
nice oil pan
Old Aug 31, 2004 | 09:58 AM
crispydee's Avatar
Default Re: (Syner-G-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARIZONA &raquo;</TD></TR><TR><TD CLASS="quote"> If I split my tap at the back of the block with a 4-way or similar ( I just don't want more than 2 fittings protruding from the block, that's just nasty and trouble waiting to happen...) and am feeding the head, sender, and the turbine... am I going to be running oil pressure thin? </TD></TR></TABLE>
Excluse me for being stupid but Why do you need to run a line to the head?
Old Aug 31, 2004 | 10:02 AM
Default Re: (crispydee)
When you add a VTEC head to an LS block the head needs an oil supply.
Old Aug 31, 2004 | 02:30 PM
crispydee's Avatar
Question answered! we never got the ls bottom end here in the uk so the LS/Vtecs are really rare.
Old Aug 31, 2004 | 02:37 PM
boost_addict's Avatar
just get the golden eagle-ls/vtec oil filter adapter. i think it as a port for a turbo feed line too
Old Aug 31, 2004 | 02:56 PM
BROOD's Avatar
Default Re: CRVTEC / LSVTEC Turbo Oil Tap questions answered *searched* (ARIZONA)
ARAZONA,
6AN line to the cyl head, I do not suggest smaller than that
4AN or 3AN to the turbo
I actually use a 6AN feed from the oil filter adapter to the cyl head, my turbo feed is 4AN and is tee'ed off from the 6AN line just before entering the cyl head. I do use a restrictor (size of the hole depends on a traditional oil bearing or a new ball bearing turbo). I have yet to have any problems. Still if you stick to the above sizes you won't have any issues with lack of supply.
Old Aug 31, 2004 | 07:12 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">nice oil pan </TD></TR></TABLE>
hawr hawr!
Old Aug 31, 2004 | 07:30 PM
kender's Avatar
whats up with the brass fitting cracking? and does this apply to a fitting made from the same stuff as the anodized an fittings ( aluminum?????not sure though)
tasco
Aug 9, 2015 02:16 PM
chrisbell37
Feb 3, 2006 06:36 AM
SHystrdyGSRtdy
Apr 22, 2005 07:54 PM
CRXDrew
Apr 14, 2005 03:55 PM
gigantor
Feb 11, 2003 08:06 AM
