? for NOS people..How much NOS for my application?
Old Dec 5, 2001 | 12:06 PM
FAST94GSR's Avatar
New User
Default ? for NOS people..How much NOS for my application?
I hvae CTR pistons with a GSR head milled 20. Compression is somewhere around 12.2-12.4:1 i believe.
I just want to be deep in the 12's and want to run a safe enough shot to do it.
Old Dec 5, 2001 | 12:58 PM
MugenSi00's Avatar
Default Re: ? for NOS people..How much NOS for my application? (FAST94GSR)
with that high CR, go with a direct port system. You need about 4 degrees of timing retard. Be sure to get a window switch too.
Old Dec 5, 2001 | 01:30 PM
sgT's Avatar
sgT
Default Re: ? for NOS people..How much NOS for my application? (MugenSi00)
be very careful of detonation problems. With that high CR you will most likely
have some so be aware.
Old Dec 5, 2001 | 04:49 PM
FAST94GSR's Avatar
New User
Default Re: ? for NOS people..How much NOS for my application? (sgT)
*****!!!!!!!! sometimes i wish my compression wasn't this high.
how are these domestic guys running big shots of nos with over 12:1 compression.
damn.
what the hell is a window switch?
Old Dec 6, 2001 | 10:21 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Just come over to my house and we'll put my kit on your car and test it out
Old Dec 6, 2001 | 12:56 PM
Mista Bone's Avatar
D Tranny Guru
It is called tuning. NOS loves compression.
Old Dec 6, 2001 | 01:22 PM
FAST94GSR's Avatar
New User
Default Re: ? for NOS people..How much NOS for my application? (Mista Bone)
Tuning? Really? Like thanks for enlightening me to that..as if I didn't already know that. everybody's telling me i'm gonna detonate cause of my compression which i agree . nitrous will boost my cylinder pressure high so I don't know how you came to the conclusion that it loves compression. I'm probably gonna have to get a bigger fuel pump, along with injectors.
Real Type R I may take you up on your offer.
Old Dec 7, 2001 | 02:51 AM
Mista Bone's Avatar
D Tranny Guru
When in doubt, go 2 jets richer on the fuel side. Better to foul a $8 set of plugs than melt a piston.
700 hp 406 Chevy with 250 shot on top................
8.92 on streetable tires through the muffs.
Not a trailer queen!
Old Dec 7, 2001 | 03:10 AM
paulzy's Avatar
if you're that concerned, get a thicker heagasket to knock it down a point...you should be fine after that...an 80 or 100 shot from a direct port system should get you deep into the 12's on slicks...
Old Dec 7, 2001 | 03:17 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: ? for NOS people..How much NOS for my application? (Slow_ass_4dr)
When Mista Bone speaks I listen. Mista, Ive been reading your post for years and you have so much to share with us.. Ive have learned so much from you over the years. Just thought I share...
art
Old Dec 7, 2001 | 06:20 AM
rtype11's Avatar
NOS is for babies its so easy to tune, the higher your CR the better it works, we had a Vette here making 800HP and then added progressive staged 500 shot, the car was around 14.5:1, that car makes jam. Always shoot for overkill on your fuel and good bottle pressure, then ground out your knock sensor and set your initial and total timing.
Old Dec 7, 2001 | 07:13 AM
Cashed EG's Avatar
Default Re: ? for NOS people..How much NOS for my application? (rtype11)
what exactly do you mean ground out your knock sensor, i've heard about this before, can you please elaborate.
Old Dec 7, 2001 | 12:54 PM
GSRacer's Avatar
New User
Default Re: ? for NOS people..How much NOS for my application? (Cashed EG)
run a small shot (eg: 50 shot) and retard you timing a bit.
mcln594
Nov 11, 2007 08:52 PM
le0ftw
Mar 24, 2007 10:44 PM
ls-v*2
Feb 28, 2007 02:52 PM
turbohf
Apr 13, 2003 11:51 AM
