jdm itr 4-1 on a da, crossmember will it clear?
Old Aug 30, 2004 | 11:09 PM
matman4444's Avatar
Default jdm itr 4-1 on a da, crossmember will it clear?
I just ordered a jdm itr 4-1 header, i have a 92 ls with a b20/vtec swap b16 head... when i put the header on will i need to do anything to the cross member? I was going to take it to a muff shop since i need a cat too, if it needs to be modified will most normal muff shops be able to do whatever it is that needs to be done?
Old Aug 30, 2004 | 11:21 PM
Slain's Avatar
you will need to either cut/or notch the crossmember..... buy a freeflow cat that is matched to your header and exhaust there for no modification needed for cat
Old Aug 31, 2004 | 12:14 AM
riceball777's Avatar
Default Re: jdm itr 4-1 on a da, crossmember will it clear? (matman4444)
you have 2 options
1 buy a aftermarket crossmember like place racing ( hangs low as hell )
2 cut the stock cross member
heres a pic of a cut stock crossmember for a 4-1 header
http://www.g2ic.com/forums/sho...ember
Old Aug 31, 2004 | 09:45 AM
matman4444's Avatar
Default Re: jdm itr 4-1 on a da, crossmember will it clear? (riceball777)
Is there anything bad that can happen when you cut that piece out? Would a normal muff shop have the tools to cut that off? I dont know how you would cut it...
I hope they dont get scared to cut it and tell me to go to hell
Old Aug 31, 2004 | 10:58 AM
91ls-v's Avatar
well...when my friend ran a comptech 4-1 header on the da we didn't have to cut the crossmember at all...it was just a pain in the *** to put on, or you could just unbolt the member and then install the header and bolt it back thats how we did it
Old Aug 31, 2004 | 11:14 AM
Colin's Avatar
Default Re: (91ls-v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ls-v &raquo;</TD></TR><TR><TD CLASS="quote">well...when my friend ran a comptech 4-1 header on the da we didn't have to cut the crossmember at all...it was just a pain in the *** to put on, or you could just unbolt the member and then install the header and bolt it back thats how we did it</TD></TR></TABLE>
That header is different from the one in question here. The crossmember needs to be cut not so the header can be placed in the bay, but instead so that it will clear once its been bolted up. Even with the notch in the member I'm pretty damn sure you'll have to drop the member just to be able to fit the header into place before bolting it up.
Old Aug 31, 2004 | 12:05 PM
matman4444's Avatar
Default Re: (91IntegGS)
well im taking it to a muffler shop to get everything done... is it for sure that the xmember needs to be cut? i saw the pic of it, but the shop will probly take that **** off and maybe it doesnt need to be cut? i dont want them to **** on me when they cant get it to fit
HoUTX98GSR
Oct 16, 2006 09:39 PM
genetsang
Jul 12, 2004 07:23 AM
silver ek
Apr 10, 2004 12:41 PM
luckypon7
Mar 16, 2004 02:39 PM
zer0zer0 TypeR
Jul 31, 2002 04:00 AM
