whistling noise from intake?dohc Zc
everytime i drive, it makes a whistling noise at around 2.5 or wen i step on it for a few seconds. it sounds like its coming from my intake. my cuzn says its caz my engine is tuned rite?? or is there sumtihing wrong that i have to fix?
it's prolly the sound of the intake sucking air which is its purpose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIhatch90 »</TD></TR><TR><TD CLASS="quote">its your blow off valve, you should goto like advance auto or some other auto parts place and tell them that you need a blow off valve</TD></TR></TABLE>
are you LD?
are you LD?
Please could you help me with this problem?
My 9 month old CRV makes a whistling noise when it is doing 2500 RPM. It only makes this noise at 2500 RPM any gear but not at any other RPM. Is this normal? It has only 3500 miles on the clock.
I've read a number of postings on the whistling noise issue and some people are saying it's because of "aftermarket intake" and some say it's because of "AEM CAI". I don't know anything about cars. Could you please tell me what is "aftermarket intake" and what is "AEM CAI"? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yew_Yun »</TD></TR><TR><TD CLASS="quote">
It replaces the stock intake system to let the motor breath more..
CAI stands for cold air intake..This involves having the intake filter mounted somewhere in the fender well to suck in cooler air..
You dont have to but a high priced aem intake though..
Thanks for your help.
My car engine hasn't been modified in any way, so how can it get this noise? Bought it brand-new from an authorised Honda dealer. First 7 months, no whistle. Then whistle for the last 2 months.
you can if it will make you feel better, but its normal like the posts above. good luck
p.s. do you have the stock air filter ? why not try taking your off intake and then putting that back on and see if the noise goes away. have you tried that yet?
normal my friends gsr with skunk2 intake mani makes the same noise and my friends crx as well, im thinking its cuase of the aftermarket intake, theres no resonaters to keep it sounding stock so thats probably why
I know of someone with a weapon R intake, and it always whistles at a certain throttle position, and I believe it is just normal. I like the noise, I think its cool. It's just air being sucked through spaces to get in the pipe.
Puffwheat
Feb 13, 2004 09:59 PM
ophdehEEzY
Apr 11, 2003 11:36 PM
