Will a JDM 4-1 header bolt to a USDM ITR cat?
Old Aug 30, 2004 | 06:18 PM
ebelp's Avatar
Default Will a JDM 4-1 header bolt to a USDM ITR cat?
Yes, I realize that the collector on the JDM 4-1 is larger than the inlet on the USDM cat, but they both share the same 2-bolt configuration that should line up. Being that it's only a 1/4" difference, it seems like it would still fit. Has anyone tried to bolt these two together?
Old Aug 30, 2004 | 06:26 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
I did it once, with my SMSP to my stock ITR cat. Itll work.
Old Aug 30, 2004 | 06:46 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (Rguy)
Isn't the JDM collector just a bit longer? I know mine didn't mate up all the way - had to drive home open header (ouch), and then to the muffler shop to get my Jeg's cat welded up to fit. That was a while ago, don't recall the details
Old Aug 30, 2004 | 06:53 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the JDM collector just a bit longer?</TD></TR></TABLE>
Yes, the JDM header is approximately 1" longer than a USDM header. There's some play in the exhaust hangers, so that might not be a problem, though I've never tried it personally.
ebelp - Out of curiosity, why would you want to bolt a JDM header to the stock cat? If you don't plan on upgrading to a larger, higher-flowing cat, you'd basically do just as well to simply buy a quality USDM-sized header.
Old Aug 30, 2004 | 06:59 PM
Rguy's Avatar
25 Year Member
Community Builder
Come to blacksburg y0, and we can figure it out.
Old Aug 30, 2004 | 07:01 PM
Bryce's Avatar
Default Re: (Rguy)
Hey man im doing almost the exact header install this weekend. I'm having to drive to the exhaust shop with the DC JDM 4-1 on the stock cat so they can replace with the high flow. Rguy has good input on this
Old Aug 30, 2004 | 07:24 PM
Splat's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">There's some play in the exhaust hangers, so that might not be a problem, though I've never tried it personally. </TD></TR></TABLE>
That must have been our problem - some play, but not enough. I could only get the cat and header halfway lined up
With stretchier (worn) exhaust hangers, you might be able to get it to line up.
Old Aug 30, 2004 | 08:33 PM
98itr0448's Avatar
Default Re: Will a JDM 4-1 header bolt to a USDM ITR cat? (ebelp)
so, to bolt it to the stock cat you need a flange and donught gasket correct? Or just the gasket? I'm planning the same install this weekend and don't want to run into any problems. I've searched, but no clear answers. bump
Old Aug 30, 2004 | 10:38 PM
TypeRPaul's Avatar
Default Re: (Bryce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryce &raquo;</TD></TR><TR><TD CLASS="quote">Hey man im doing almost the exact header install this weekend. I'm having to drive to the exhaust shop with the DC JDM 4-1 on the stock cat so they can replace with the high flow. Rguy has good input on this </TD></TR></TABLE>
why go through that, just give dave at SMSP a call and he can get u set up with a nice cat that will fit...BIG to Daves work!
Old Aug 31, 2004 | 03:14 AM
Asahi's Avatar
Default Re: Will a JDM 4-1 header bolt to a USDM ITR cat? (98Itr-0448)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Itr-0448 &raquo;</TD></TR><TR><TD CLASS="quote">so, to bolt it to the stock cat you need a flange and donught gasket correct? Or just the gasket? I'm planning the same install this weekend and don't want to run into any problems. I've searched, but no clear answers. bump</TD></TR></TABLE>
The clear answer is a JDM style header is longer than a USDM header and requires a shortened cat to bolt up properly. You CAN bolt a USDM cat to a JDM header but them the cat will be too far back to bolt to the USDM B pipe. You need an aftermarket cat and while you are at it you should use a 2.5" in/out cat to utilize what the advantages to a JDM header are.
Old Aug 31, 2004 | 04:14 AM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">ebelp - Out of curiosity, why would you want to bolt a JDM header to the stock cat? If you don't plan on upgrading to a larger, higher-flowing cat, you'd basically do just as well to simply buy a quality USDM-sized header.</TD></TR></TABLE>
I guess I'm just impatient. I have the JDM header just waiting to be installed. I hate looking at it everyday just sitting there doing nothing. I haven't purchased a high-flow cat yet, but my stock cat was turned into a high-flow by the previous owner , I know it'll flow a bit better than stock.
redGSRguy
Aug 12, 2009 06:27 PM
ednyboo
Apr 26, 2007 05:10 AM
00-501itrspec
Oct 13, 2005 08:52 PM
TheSquirrel
Dec 12, 2004 08:37 PM
austrian type-R
Feb 16, 2004 02:39 PM
