ITR header question
Old Dec 12, 2004 | 06:58 PM
TheSquirrel's Avatar
Default ITR header question
Ight i have great issues with searches i cna never come up with what im looking for, so if its there already i dont want to here a lot of fussin, I have a '94 gsr and just need to know if a type-r header will just bolt on to the stock cat or if i need to change rest of my exhaust as well.
Old Dec 12, 2004 | 07:39 PM
dFreezy's Avatar
Default Re: ITR header question (TheSquirrel)
the usdm type r header will bolt up to your head and fit your stock cat, but modification may be needed since the length of the a-pipe (the lower portion of the header) is slightly different on type r's than on 94-99 gsr's.
Old Dec 12, 2004 | 07:46 PM
G-bonic's Avatar
Hijacked
yes it will bolt rite on, but remember that jdm itr collector is 2.5 while the usdm cat inlet is 2.38 and the hole where u put bolts wont line up... so just get a aftermarket or jdm itr cat too..
Old Dec 12, 2004 | 07:50 PM
dFreezy's Avatar
Default Re: ITR header question (Stock_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock_LS &raquo;</TD></TR><TR><TD CLASS="quote">yes it will bolt rite on, but remember that jdm itr collector is 2.5 while the usdm cat inlet is 2.38</TD></TR></TABLE>the usdm type r header has a 2" collector, so an aftermarket cat isn't needed.
Old Dec 12, 2004 | 07:53 PM
G-bonic's Avatar
Hijacked
Default Re: ITR header question (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">the usdm type r header has a 2" collector, so an aftermarket cat isn't needed.</TD></TR></TABLE>
oh yeah mah bad.. i was talkin about the piping of usdm itr...
btw he didnt specify too if its jdm itr or usdm itr headers
Old Dec 12, 2004 | 07:56 PM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock_LS &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah mah bad.. i was talkin about the piping of usdm itr...
btw he didnt specify too if its jdm itr or usdm itr headers </TD></TR></TABLE>
USDM ITR exhaust piping is not 2.36 (60mm), if my memory serves it is closer to 2.25 with a couple of 2 inch bottlenecks.
Old Dec 12, 2004 | 07:58 PM
dt4life's Avatar
i have a usdm ITR header for sale if anyone is interested
Old Dec 12, 2004 | 08:26 PM
dFreezy's Avatar
Default Re: ITR header question (purplegsr (Exospeed))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) &raquo;</TD></TR><TR><TD CLASS="quote">
USDM ITR exhaust piping is not 2.36 (60mm), if my memory serves it is closer to 2.25 with a couple of 2 inch bottlenecks.</TD></TR></TABLE>memory serves correctly, that is correct
Old Dec 12, 2004 | 08:37 PM
Default Re: ITR header question (wannaTypeR)
how much you want for it, also ill have to check to see if the ones i was lookin at are usdm or jdm, but thanks for the info
StayTuned12
Aug 17, 2005 10:31 AM
ebelp
Aug 31, 2004 04:14 AM
luckypon7
Mar 16, 2004 02:39 PM
sExy_TinKY
Sep 25, 2003 07:21 PM
skafia
Dec 6, 2001 06:56 AM
