How to get Slipstreams and 205 azenis not to rub??
Old Aug 30, 2004 | 03:53 PM
Chronicsinners's Avatar
Default How to get Slipstreams and 205 azenis not to rub??
As the topic states, i recently put my Slipstreams and azenis on the car, and it is rubbing in the back badly, i was wondering what people did to rectify this problem. My car isnt terribly low, i have searched and people have said that they roll the fenders, im sure this would help, but i was wondering if there were any better solutions, thanks in advance
-bob
Old Aug 30, 2004 | 04:10 PM
crxgsr91's Avatar
Default Re: How to get Slipstreams and 205 azenis not to rub?? (Chronicsinners)
What is the exact size of your tires?
I run Eagle F-1 215 40ZR 16's and they do not rub.
Old Aug 30, 2004 | 04:11 PM
4drEF's Avatar
Keyboard Humorist
Roll them.
Or lower your car without camber correction.
Old Aug 30, 2004 | 04:22 PM
fourthgenhatchB17's Avatar
Default Re: How to get Slipstreams and 205 azenis not to rub?? (4drEF)
I had that same problem. Luckily i was trying out my friend's 205 azenis on slips, and when i found out they rubbed, i just gave them back. The widest i go is 195. Rolling the lip should help u out.
Old Aug 30, 2004 | 04:23 PM
Targa250R's Avatar
be professional
Default Re: How to get Slipstreams and 205 azenis not to rub?? (crxgsr91)
If you're rubbing on the fenders, you could:
- dial in more negative camber
- get wheels with a numerically higher offset
- roll the fenders
- raise up the car
- use higher spring rates
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">What is the exact size of your tires?
I run Eagle F-1 215 40ZR 16's and they do not rub.</TD></TR></TABLE>
He is most likely running the 205/50-15 Azenis, which are actually around 219mm wide.
Old Aug 31, 2004 | 10:45 AM
Default Re: How to get Slipstreams and 205 azenis not to rub?? (Targa250R)
yea i am running the 205's, i am planning on rasing the back a 1/2 inch or so, and i guess rolling the fenders, i was just wondering if there were any other solutions thanks for the help
Old Aug 31, 2004 | 10:50 AM
Driven's Avatar
15x6.5
205/50-15
no rubbing. But, my fenders are slightly rolled and i'm not "slammed"
Old Aug 31, 2004 | 10:55 AM
Mr.Saturn's Avatar
Default Re: How to get Slipstreams and 205 azenis not to rub?? (Driven)
205/50/15s on 15x7 Rotas here. One washer for camber (about +0.5 degrees) and my car isn't slammed either. No rubbing at all.
Old Aug 31, 2004 | 11:27 AM
Jlo96Hatch's Avatar
If you bend it just use a rubber body hammer, It shouldn't take you long at all.
Old Aug 31, 2004 | 12:03 PM
HT Chaplain's Avatar
Loved
do 205/50/15 rub at stock height with 15X7?
Old Aug 31, 2004 | 12:43 PM
TrueNorthStar's Avatar
Default Re: How to get Slipstreams and 205 azenis not to rub?? (Jlo96Hatch)
heh I run 215/45/16's azenis on some enkei's lowered on h&r springs, I only rub if I have allot of weight in the trunk (like scuba gear for 2). I used the "baseball bat" rolling method.
Old Aug 31, 2004 | 03:01 PM
SETI20's Avatar
Usually rubbing on the rear is due to the offset.
Look into it. You'll love me when you find the car handling alot better with the proper offset.
Old Aug 31, 2004 | 10:24 PM
Mr.Saturn's Avatar
Default Re: How to get Slipstreams and 205 azenis not to rub?? (HT Chaplin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin &raquo;</TD></TR><TR><TD CLASS="quote">do 205/50/15 rub at stock height with 15X7?</TD></TR></TABLE>
Hell no! lol and not on a 2" drop either, about -1.0 camber both sides, neutral toe, no problems at all
myevoisweksos
Oct 26, 2009 06:52 PM
civicnoob
Dec 31, 2008 01:11 PM
JC VTEC
Oct 9, 2005 02:49 PM
2000si
33
Dec 3, 2003 10:46 PM
V-Grip! Teknic73
Mar 2, 2003 10:33 PM
