Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Is there any advantage to port and polishing a ITA crx head?
Old Aug 30, 2004 | 06:43 AM
Chris Sawatsky's Avatar
New User
Default Is there any advantage to port and polishing a ITA crx head?
with the limitations on porting and polishing in IT rules, is there any advantage to be had from doing this finishing work on an ITA CRX head?
the limitations are you can only remove material 1" from the flange, either way, d16a6 head
thanks
Old Aug 30, 2004 | 06:48 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Re: Is there any advantage to port and polishing a ITA crx head? (Chris Sawatsky)
The rulebook would be the definitive source on this matter, but last I recall, porting and polishing of the head was limited to 1 inch in from the gasket.
So, the advantage I guess would be it relieves you from having to worry about those silly IT rules, cuz you aren't legal for IT anymore.
Old Aug 30, 2004 | 06:55 AM
New User
Default Re: Is there any advantage to port and polishing a ITA crx head? (madhatter)
yes I know what the rules are. I'm asking if there is any advantage to doing port and polish work while abiding by the rules. 1" in from the gasket isn't very far, so perhaps there isn't much advantage to be gained
Old Aug 30, 2004 | 07:02 AM
CRX Lee's Avatar
I have never done it on an IT head as I have been told the Honda ports are pretty good and have always confirmed it with a good match to the gaskets and no blockage. On the otherhand, most of this experience was before the days when dynos were so handily available to local racers and there weren't many cylinder head prep companies messing with Hondas.
Now things have changed and I have not heard really what kind of quantified gains people are finding on IT heads. I would be interested to hear if there was any real gain.
Old Aug 30, 2004 | 07:37 AM
Crack Monkey's Avatar
Default Re: Is there any advantage to port and polishing a ITA crx head? (CRX Lee)
I imagine the psycological gain is probably as large as the horsepower gain. One less thing to secondguess or pass-blame.
Old Aug 30, 2004 | 08:24 AM
metalworker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee &raquo;</TD></TR><TR><TD CLASS="quote">
Now things have changed and I have not heard really what kind of quantified gains people are finding on IT heads. I would be interested to hear if there was any real gain.</TD></TR></TABLE>
I don't think I would believe what I was told anyway.
Old Aug 30, 2004 | 08:50 AM
CRX Lee's Avatar
Default Re: Is there any advantage to port and polishing a ITA crx head? (metalworker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metalworker &raquo;</TD></TR><TR><TD CLASS="quote">I don't think I would believe what I was told anyway.</TD></TR></TABLE>
Truth...or at least more trustworthy than any quoted numbers.
So would numbers from a flow bench be sufficient or would they need to come from a dyno? It would be easier to take a clean, stock, valveless head and get a flow bench measurement and then try a valveless ported head back to back. You get no effect of the valve grind itself but you see the max air flow, that is if the porting was a was the weakest link in the chain and the limiting factor. I guess this set-up would show the maximum capacity for effect even if it made no difference on the engine. I have a few spare used stock heads that it might be interesting to play with porting but that is if you felt the time and effort was best spent there.
Wait a minute...first you make the car run, then you develop. Developing a non-running car doesn't do much for increasing seat time.
Old Aug 30, 2004 | 09:02 AM
Send me a head, I'll send it back with everything I know. I just won't tell you about it.
Old Aug 30, 2004 | 10:19 AM
Catch 22's Avatar
The perfect match-up between the intake and exhaust manifolds is what you're after. If you already have it... Skip the port matching. I didn't already have it.
Gains... I dunno. probably not much. Maybe a HP at the top end.
But if you have everything apart and are doing machine work anyway, why the hell not go ahead and do it.
JMO.
SlowPokeEg
Mar 22, 2008 09:10 PM
Tigfab
Jun 3, 2007 03:04 PM
CTR-CRX
Mar 14, 2004 07:07 PM
bstock1990
Jan 27, 2003 09:41 PM
