what gauge wire should i use when wiring a fan too a toggle switch..??
What gauge wire from battery to toggle switch..??
what gauge wire from fan too toggle switch..??
and what gauge wire for the ground...??
Also..should i install an inline fuse between the fan and toggle or the battery and toggle........?? thanks in advance..
It all depends on the fan you are installing. How many amps does it require? You should always fuse any new circuit you install.
Well I dont know how many amps the stock fan requires but I doubt its more than 10 so you should be fine with AWG #20 or larger.
and i would use 14g wire and do a inline fuse, i wired my rad and ac fan to a switch but the wire was getting hot when i used 16g
