prospeed header touching crossmember
Old Aug 29, 2004 | 10:15 PM
es_squared's Avatar
Default header touching crossmember
initialy the header had probly like an inch clearance, but then i rearended someone, and after i got my car back and checked the clearance again and its pretty much touching the crossmember, and i htink i can feel it tghrough the pedals when i rev the engine. just want to know if its ok , or any pointers you guys could give me on how to fix it.. nothc the crossmember maybe?
Modified by es_squared at 11:20 AM 8/30/2004
Old Aug 29, 2004 | 10:18 PM
revlimitx04's Avatar
Default Re: prospeed header touching crossmember (es_squared)
Notch that ****
Edit:
Errr, how bad did you rearend someone, whyd your exhaust move back....
Old Aug 29, 2004 | 10:21 PM
es_squared's Avatar
Default Re: prospeed header touching crossmember (revlimitx04)
******* lame. no, looking at the header and exhaust , doesnt look like they moved at all. i rearended going probly 35kmph
Old Aug 30, 2004 | 07:11 AM
Daemione's Avatar
Umm, take it back to the place that "fixed" your car, and have them do it right. Seems pretty obvious the front end is still pushed in.
Old Aug 30, 2004 | 07:20 AM
Monkeyballs's Avatar
Default Re: prospeed header touching crossmember (Daemione)
yeah, my header does that...its a kamikaze tho...
Old Aug 30, 2004 | 07:25 AM
Kal's Avatar
Kal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">Umm, take it back to the place that "fixed" your car, and have them do it right. Seems pretty obvious the front end is still pushed in.</TD></TR></TABLE>
Old Aug 30, 2004 | 08:24 AM
98TypeSH's Avatar
Default Re: prospeed header touching crossmember (Kal)
It shouldent say "prospeed header...." Any header would probably be touching after you smashed into someone. As stated before, take it back to the place that "fixed" your car, and tell them to stop ******* around.
Old Aug 30, 2004 | 10:20 AM
es_squared's Avatar
Default Re: prospeed header touching crossmember (98TypeSH)
I HATE BODY SHOPS!
Old Aug 30, 2004 | 10:32 AM
ItalynStylion's Avatar
Default Re: prospeed header touching crossmember (twopoint5lude)
Your kamikaze header touches b/c you got in a wreck or has it always done that?
Old Aug 31, 2004 | 07:49 AM
Default Re: prospeed header touching crossmember (ItalynStylion)
always done it, since i put it on.................but to be honest, i think my car has been in a wreck before.
Old Aug 31, 2004 | 12:45 PM
twopoint5lude, do a Vin check on it, and next time your in your enginebay look at the lower radaitor support. if somthing is shady the car probably was in a wreck. but the vin check should tell you.
Old Sep 3, 2004 | 09:47 AM
es_squared's Avatar
ok i had a closer look and its actualy go like about an inch cloearance
kaj
Jan 11, 2008 03:29 PM
import_trung
Honda S2000
Apr 12, 2007 06:12 PM
RGoose18
Jun 7, 2006 02:56 PM
Dc2 Powered
Jul 2, 2004 03:31 PM
AintegraA
Dec 11, 2003 11:43 AM
