Info: OBD 1 jdm p13's
Old Aug 29, 2004 | 02:25 PM
H22aAccord's Avatar
Default Info: OBD 1 jdm p13's
Do obd1 JDM p13's for the H22a's have a built in rev limiter or not???
http://www.clubhonda.com/forum...13116
Old Aug 29, 2004 | 02:35 PM
EuRoBrO's Avatar
Default Re: Info: OBD 1 jdm p13's (H22aAccord)
Yes they do. I believe its anywhere between 7400-7600.
Old Aug 29, 2004 | 03:45 PM
2lude4u's Avatar
Default Re: Info: OBD 1 jdm p13's (EuRoBrO)
USDM P13 ECU's don't have the rev limiter, but have a slightly leaner mixture. I have one if interested.
Old Aug 29, 2004 | 03:57 PM
specialedition's Avatar
Default Re: Info: OBD 1 jdm p13's (2lude4u)
he did not ask about usdm p13 ecus but the jdm p13 ecu -- I rev my jdm h22a with jdm p13 ecu to 7695 rpm on the tell tell Vafc and wonder how it hit that high scared the sheat out of me I thought they have rev limiters but have heard they do not on jdm cars but have fuel cutoffs instead ---
Old Aug 29, 2004 | 04:10 PM
ernestoG's Avatar
Default Re: Info: OBD 1 jdm p13's (specialedition)
fuel cut (or rev limiter whatever...)on my jdm h22 with p13 is 8000 on stock tach so prolly right around 7600 7800 actual rpms.
Found that out by letting my dad drive the car......that bastard.
Old Aug 29, 2004 | 05:26 PM
v4lu3s's Avatar
RTFM
every stock p13 i have used is about a 7600 rpm rev limit, and i currentyl have 1 jdm and 1 usdm and a 3rd one i havent opened to check yet.
Old Aug 29, 2004 | 06:01 PM
Behan's Avatar
Default Re: (v4lu3s)
The JDM p13 ecu has a 117 mph governor.
Other then that the jdm and usdm p13's rev limiter's are the same.
Old Aug 29, 2004 | 06:49 PM
Default Re: (Behan)
then why did my h22a jdm p13 ecu rev to 7700 rpm without hitting a rev limiter.. .I have just kinda been shocked by this swap deal I do not know what car (prelude 4th gen) my engine came from and what type of work was done to it while in japan but it put down almost 200whp and this is a n/a h22a --- but the engine reved over and went to 7695 rpm so does the vafc cut the rev limiter or would aftermarket cams and head work with a reworked ecu do that ...
Old Aug 29, 2004 | 06:55 PM
Quick99Si's Avatar
Default Re: (specialedition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specialedition &raquo;</TD></TR><TR><TD CLASS="quote">then why did my h22a jdm p13 ecu rev to 7700 rpm without hitting a rev limiter.. .I have just kinda been shocked by this swap deal I do not know what car (prelude 4th gen) my engine came from and what type of work was done to it while in japan but it put down almost 200whp and this is a n/a h22a --- but the engine reved over and went to 7695 rpm so does the vafc cut the rev limiter or would aftermarket cams and head work with a reworked ecu do that ... </TD></TR></TABLE>
Try taking it to 8500 and you'll see it's not possble one a stock ECU.
Didn't we have this discussion a few weeks ago? Every Honda ECU I know of has a rev limiter. The speed limiter is a different thing... JDM P13 is at 180k/h btw
Adi
Old Aug 29, 2004 | 07:21 PM
v4lu3s's Avatar
RTFM
at 7600 the fuel cut occurs, and it will over rev slightly past that, before backing back down below the fuel cut.
Old Aug 29, 2004 | 07:45 PM
H22aAccord's Avatar
damn 117 mph speed govenor, that sucks!!
Old Aug 29, 2004 | 08:03 PM
Quick99Si's Avatar
Default Re: (H22aAccord)
It's easily bypassed with an s200 for example, Field AFC, and a few other lesser known piggybacks/meters
Adi
Old Aug 29, 2004 | 08:07 PM
thank you that was what I was after I could feel it lose power after the fuel cut at 7600 but it went straight into vtec when I shifted to second.... so that could explain it ---
Old Aug 30, 2004 | 03:42 AM
H22aAccord's Avatar
And hittting the fuel cut off isnt hurting the motor?
Old Aug 30, 2004 | 05:55 AM
v4lu3s's Avatar
RTFM
hitting it occasioanlly is not terrible, but doing it every gear is bad.
Old Aug 30, 2004 | 06:34 AM
satan_srv's Avatar
7800. done
darkstar1440
Sep 28, 2006 08:37 PM
ozzyman
Oct 16, 2003 10:35 AM
Jago
Oct 18, 2002 11:32 AM
