vacuum leak somewhere, checked and rechecked
Old Aug 29, 2004 | 12:45 PM
ludacole's Avatar
Default vacuum leak somewhere, checked and rechecked
i have a idle issue, my idle jumps from 1200 to 1300 really fast. IACV you say? FITV you say? well ive checked and rechecked both and i know its not those. when i take my intake off and cover up my throttle body my car continues to run. even with the entire intake opening closed off i can slowly rev up to 8000 rpm. with that said i know im sucking in air somewhere. i took my mani off and replaced the gasket and all bolts are tight. all my injectors are sealed tightly also. i capped off all my vac nipples on my mani and the intake and still air is being drawn in, BUT WHERE FROM???? if anyone has ever had this problem or know how to fix it please any ideas are welcome. thanks in advance.
fyi= its a obd1 jdm gsr into a 94 civic ex coupe
Old Aug 29, 2004 | 12:53 PM
vtec69's Avatar
Default Re: vacuum leak somewhere, checked and rechecked (ludacole)
wow dude im stumped on that one
Is it just when the car is cold and not warmed up?
Or is it all the time?
Old Aug 29, 2004 | 01:29 PM
ludacole's Avatar
Default Re: vacuum leak somewhere, checked and rechecked (vtec69)
all the time my friend, cold, warm, hot, it doest matter.
Old Aug 29, 2004 | 02:01 PM
IVI's Avatar
IVI
spray some carb cleaner around the hoses and when the motor bogs look into that area more.
when the vaccum leak sucks up carb cleaner it will bog the motor.
Old Aug 29, 2004 | 03:38 PM
ludacole's Avatar
Default Re: vacuum leak somewhere, checked and rechecked (IVI)
found it!!!!!!!! on the bottom of my mani there is a hidden vac line, i could see and and it was hooked to the mani, but it hooks up to a oil canister and it looks connected but it wasnt. thanks for the help, i love hondas!
hun8504
Dec 26, 2012 09:37 AM
Famous94LS
Apr 16, 2009 06:34 AM
90crxdriver
Jun 24, 2007 03:32 AM
Gsir8
Jan 8, 2007 04:42 PM
Fly1865
Mar 31, 2003 11:24 AM
