89 Civic electrical system question - a short causing accessories not to work?
Old Aug 29, 2004 | 09:55 AM
MikeMidd's Avatar
Default 89 Civic electrical system question - a short causing accessories not to work?
Little background here: 89 Civic had a flat tire, GEICO-dispatched truck came to fill it, guy plugged in a small compressor into the cig lighter to try to fill the tire.
Turned on the car (started fine) and the lighter wasn't sending power to the small compressor, didn't work at all. Simultaneously the dome light went out, clock darkened, etc. Radio presets have all been reset to the defaults. Trunk-open warning light is now permently on, even when trunk is closed, but when open, warning light glows at a brighter red. Headlamps seem to work fine, radio works fine except for losing presets, power locks are good, etc.
What happened, and how do I fix it so everything works normally again - is this a simple thing like a blown fuse, or something bigger (short in the system that is more serious)? Battery seems to be working fine. What can I do to get things back together?
Thanks.
Laidbackdriver
Jun 11, 2016 09:25 AM
bullets
Aug 24, 2006 12:51 PM
