cracked block wtf?
Old Aug 29, 2004 | 06:29 AM
MrSmith's Avatar
Default cracked block wtf?
94 GSR block 100k on it total 2k since rebuild. Was running fine except I began losing coolant on a daily basis you could see wet spots on the block under the manifold behind the turbo.... first I thought it was the main coolant plug on the bottom left leaking but I was wrong. Pulled off the kit multiple hairline cracks all the way down the block. I have never seen/heard of anything like this happening. I was only running 13 psi maybe 330 wheel if that. I suppouse I just got stuck with a bad block
Pics:
If red x imagestation is not working.
Old Aug 29, 2004 | 06:55 AM
EM1 MIKE's Avatar
Damn sorry to see that man. I also have never heard of that happening before. What are you planning on doing now? New block?
Old Aug 29, 2004 | 06:56 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: cracked block wtf? (MrSmith)
First time I actually seen something like that. Sorry to hear that bro.
Old Aug 29, 2004 | 06:59 AM
Curtis2kul's Avatar
Default Re: cracked block wtf? (NVturbo)
i know a guy that bought a 240 off a friend and it turns out to have had a crack in the block so he just jb welded it during shop class one day
Old Aug 29, 2004 | 07:26 AM
Boosted Chemist's Avatar
Default Re: cracked block wtf? (Curtis2kul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curtis2kul &raquo;</TD></TR><TR><TD CLASS="quote">i know a guy that bought a 240 off a friend and it turns out to have had a crack in the block so he just jb welded it during shop class one day </TD></TR></TABLE>
i would try this, i mean screw it the block is done so there is nothing to lose
Old Aug 29, 2004 | 07:30 AM
Ri5e's Avatar
Try welding up where it's cracking. What kind of engine mounts are you using?
Old Aug 29, 2004 | 07:47 AM
G
sh!t happens.
Default Re: cracked block wtf? (BG Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost &raquo;</TD></TR><TR><TD CLASS="quote">
Try welding up where it's cracking. What kind of engine mounts are you using?</TD></TR></TABLE>
What all would casue a motor to do that? Would mounts matter?
Old Aug 29, 2004 | 08:22 AM
boosted_dc2's Avatar
Default Re: cracked block wtf? (G"UNIT)
just have somone weld some beads over the cracks, but **** i dont know what would cause that.
did you ever add cold coolant when the engine was hot???
Landon
Old Aug 30, 2004 | 04:56 AM
MrSmith's Avatar
Default Re: cracked block wtf? (boosted_dc2)
Thought about welding it but with the way the block looks I dont think I am going to bother. If there was one small crack that would be one thing but there are a number of them. Who knows whats going on on the inside of the block. There could be a giant crack going across for all I know. Not worth my time to weld it and have it crack again down the line.
Coolant was added as needed. At first it was losing half the reservoir after one day of driving then it became the entire reservoir after 45 min of hard driving as i imagine the cracks expanded/more formed. I would let the car cool to the point of being able to pop off the rad cap to check level before adding coolant.
I have solid filled mounts if that makes a difference.
My rotating assembly is still good so I am probably just going to find a bare virgin block and swap everything over.
Old Aug 30, 2004 | 05:37 AM
Stewie's Avatar
sounds like you had some cooling issues like a bad water pump or thermostat that didn't allow proper cooling of the block. [font color=red]cooling [/font]
<FONT COLOR="Blue">luck</FONT>
Modified by Stewie at 5:00 PM 9/7/2004
Modified by Stewie at 5:01 PM 9/7/2004
Modified by Stewie at 5:02 PM 9/7/2004
Modified by Stewie at 5:04 PM 9/7/2004
360infinite-usa
Jun 26, 2012 12:42 PM
jspeedy
Mar 18, 2004 06:49 PM
im_poor
Dec 14, 2003 08:19 AM
4doorH22
Mar 9, 2003 01:26 AM
b18cTurbo
Dec 11, 2001 03:40 PM
