fan fuse
im not sure about the fuse, but the fan thing might be the relay i guess its kinda common in the hatchs mine went out so i wired a switch to controll both my ac and rad fans
wire the ac fan TO the rad fan . and then you put a switch to the ground (what i did) but ive been told that you should use a relay. the reason why is because my switch started to heat up, but i relocated the switch and its been fine since. oh and i didnt use a relay because i dont know how
just let me know if you need more info or help
