94 Accord EX - slow acceleration
Old Aug 28, 2004 | 07:15 PM
jade94accordex's Avatar
Default 94 Accord EX - slow acceleration
Recently purchased this car, have done minor tune-up (changed air filter, PCV valve, plugs, oil/filter, tranny fluid and two bottles of injector cleaner).
When pressing the accelerator you must do it slowly or the car will "bog" down, once the speed reaches 15-20mph it accelerates fine.
This condition makes it a little nerve racking when trying to get out at busy intersections!!
Any suggestions for improvement?
TIA
Old Aug 28, 2004 | 07:28 PM
DragonTLS's Avatar
Default Re: 94 Accord EX - slow acceleration (jade94accordex)
2 bottles of fuel injector cleaner? did you mix up the spark plug wires,
Old Aug 28, 2004 | 07:30 PM
Default Re: 94 Accord EX - slow acceleration (DragonTLS)
Added the bottles on different tanks.
No, I believe the wires are in the right order but will double check.
Old Aug 28, 2004 | 07:37 PM
sj993's Avatar
Yep, I've got the same problem. Been that way for awhile now and I can't figure out what the deal is.
Old Aug 31, 2004 | 05:45 PM
DragonTLS's Avatar
check for codes, could be a bad TDC sensor inside the distrubutor
Old Aug 31, 2004 | 06:30 PM
Pardon my ignorance but how do you go about finding these codes?
Old Sep 1, 2004 | 08:53 PM
DragonTLS's Avatar
look for a blue 2 pin connector on the front passenger side kick panel, jump
the connector and turn key to accessory on, look at the check engine light if it
blinks count the long blinks and short blinks
Old Sep 2, 2004 | 07:49 AM
Thanks, I'll check it out
Old Sep 2, 2004 | 10:23 AM
Vic Nyce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragonTLS &raquo;</TD></TR><TR><TD CLASS="quote">look for a blue 2 pin connector on the front passenger side kick panel, jump
blinks count the long blinks and short blinks</TD></TR></TABLE>
my car bogs too...96 EX 5sp, i havent done a tune up yet tho. maybe its that.
wouldnt the light only blink if its steadily on while the engine is on?
Old Sep 2, 2004 | 12:39 PM
2wickedtoyz's Avatar
did you change the fuel filter? and des it idle properly? try tb cleaner but make sure its fi safe
Old Sep 2, 2004 | 03:40 PM
RnEpmc's Avatar
do you count it like long long short long short short. or 4 longs 3 shorts.?? what do ou do after you have done that
Old Sep 2, 2004 | 04:52 PM
Default Re: (2wickedtoyz)
It idles smooth, but I have not replaced the fuel filter.
Someone said it could be the torque converter?
Mtwostwo
Jan 2, 2012 11:59 AM
Mtwostwo
Engine Management and Tuning
Jun 14, 2010 08:24 AM
Accord5Gen
Dec 19, 2009 09:26 AM
jaredvabeach
Jan 18, 2009 09:46 AM
MrMug3n
Dec 11, 2008 03:42 PM
