H22 tranny noise... problem
Old Aug 28, 2004 | 06:17 PM
rhaccord's Avatar
Default H22 tranny noise... problem
I have a 4th gen with h22 and w/ auto-manual conversion. 6 months ago I put in a diff clutch and fidanza flywheel. About a month or two ago I notice a noise (screeching sound) not bad but definitely noticeable when letting the clutch slip into first and the same when going into reverse. Seems to do it only when the engine is cold. Over the last month the noise has gotten louder and lasts longer from cold start up. I drained tranny fluid and refilled and that didn't make a difference. I am thinking it could be the throwout bearing. Anyone have any thoughts?
If it is the throughout (or release) bearing are all of them universal or am I going to have to contact the manufacturer of the clutch I got that came with the bearing?
Old Aug 29, 2004 | 11:52 AM
rhaccord's Avatar
Default Re: H22 tranny noise... problem (rhaccord)
Old Sep 6, 2004 | 08:26 PM
rhaccord's Avatar
nobody has any thoughts
Old Sep 6, 2004 | 08:29 PM
-RedneckDave-'s Avatar
Working
It could be the release bearing, or it could be the flywheel making noise. You probably need to drop the tranny and check them out. It is a pain but that is what I would do.
Old Sep 7, 2004 | 06:42 PM
rhaccord's Avatar
Default Re: H22 tranny noise... problem (-RedneckDave-)
Yeah I know that dropping the tranny is going to be necessary (dammit!) but what do you think it could be on the flywheel?
Old Sep 7, 2004 | 06:51 PM
v4lu3s's Avatar
RTFM
id lean towarsd throwout bearing, or the input shaft bearing but more likely the t/o bearing
99teg
Jun 14, 2006 02:44 PM
Turbo_Mike
Oct 6, 2005 08:18 AM
Emshhh
11
Feb 2, 2005 11:10 PM
E-lude78
Mar 13, 2002 05:29 PM
E-lude78
12
Mar 12, 2002 05:37 AM
