where is the airbag module or brain located?
It's not anywhere near the dash.
In a coupe, it's on the passenger side where the back seat passenger would be sitting. To the right is the plastic panel (the one where the speaker grill is attached to).
That entire panel has to be removed, it's a pain because it goes all the way back into the trunk. Right in front of the speaker is the airbag module. I'll see if I can find a pic for you.
EDIT AGAIN AGAIN
: No idea where it is on a sedan though.
EDIT AGAIN: I found the better pic. It's that grey box thing that the arrow is pointing at.
EDIT AGAIN AGAIN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">It's not anywhere near the dash.
EDIT AGAIN AGAIN
acutally that is the brain for the ABS
the brain for the air bags , is behind the radio area, there is a large yellow plug in it
it will be covered with a plastic case
EDIT AGAIN AGAIN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">acutally that is the brain for the ABS
it will be covered with a plastic case</TD></TR></TABLE>
Blah! You sure? Damn, I haven't looked in an Integra in a while. Sorry for posting wrong info then.
this is the main plug that goes into the airbag module
follow the plug and you'll find the brain
all yellow colored plugs have to do with SRS
93dagsr
Jan 22, 2008 10:31 AM
M-EJ1
30
Jun 30, 2006 09:07 PM
