jdm b18c1 Running rich all of a sudden.?
Seems my stock JDm b18c1 block P72 Head (OBD1 p72 ECU) is running rich now at WOT. It used to run just in the rich range still a bit stoike. This is on my Autometer A/F gauge. Also my friend last night he said that when i nailed the thorttle he could smell gas?
What could cause this? I am at 16 degreed ignition, i was thinking mabey 18 should help this.............i did remove the CAT recently and was thinking mabey this is causing some issues with the OBD1 system.
Modified by B HATCH at 6:46 PM 8/28/2004
Modified by B HATCH at 6:47 PM 8/28/2004
Actually on your car the map might read right off the throttle body, but if it doesn't it should be right behind your TB on the firewall, looks like a little top hat.
jxhxb
Oct 26, 2009 07:21 PM
bigwally9876
Mar 24, 2008 08:50 PM
