fan wont turn on...
Old Aug 28, 2004 | 08:15 AM
xsellxoutx's Avatar
Default fan wont turn on...
well i know that my fan works and the relay is good anybody have an idea? also yes the fan is plugged in and the fuses are good
Old Aug 28, 2004 | 12:31 PM
Cynical 1's Avatar
Default Re: fan wont turn on... (xsellxoutx)
Coolant temp switch working/functional?
Old Aug 28, 2004 | 01:34 PM
xsellxoutx's Avatar
Default Re: fan wont turn on... (Cynical 1)
on the therma-housing? the gauge works
Old Aug 28, 2004 | 02:30 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx &raquo;</TD></TR><TR><TD CLASS="quote">on the therma-housing? the gauge works </TD></TR></TABLE>
the gauge doesnt work off the thermoswitch. are you over heating? my motor runs really cool so my fan doesnt turn on unless i'm idling for a long time. try unhook the thermoswitch plug and bridging the contacts with you motor running. the fan should turn on
Old Aug 28, 2004 | 03:51 PM
xsellxoutx's Avatar
Default Re: fan wont turn on... (dantastic)
well the fan works when its hooked to the battery directly....and yes it does over heat...
Old Aug 28, 2004 | 08:04 PM
xsellxoutx's Avatar
also when i jump plug on the thermahousing the fan doesn't come on.
Old Aug 29, 2004 | 04:24 PM
xsellxoutx's Avatar
ttt
Old Aug 29, 2004 | 04:28 PM
Boostage's Avatar
when my fan didnt come on. I changed teh coolant temp sensor.. didnt work. then I replaced the fan relay.. works now. a relay is like $25 and autozone or pepboys. it goes in that box next to the battery.
Old Aug 29, 2004 | 07:45 PM
xsellxoutx's Avatar
Default Re: fan wont turn on... (Boostage)
the relay is good...i'm just gonna try the temp switch
Old Aug 29, 2004 | 07:47 PM
slambedcivic's Avatar
how do you know the relay is good?
Old Aug 29, 2004 | 08:39 PM
Blackhtch's Avatar
if u jumped the switch and it didnt come on and u said u tested the fan. then its gotta be the fan relay.
Old Aug 29, 2004 | 09:24 PM
Civic92Turbo's Avatar
having almost the same problem...the fan only turns on when i have the key in the ign...but when i dont it turns off...
Old Aug 29, 2004 | 09:29 PM
nocturnaldragon's Avatar
Default Re: (Civic92Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic92Turbo &raquo;</TD></TR><TR><TD CLASS="quote">having almost the same problem...the fan only turns on when i have the key in the ign...but when i dont it turns off...</TD></TR></TABLE>
You think its possibly because you turned the car off with everthing else? INCLUDING THE FAN!? im gonna go cry the amount of stuiped responses is making mikey sad today
Old Aug 29, 2004 | 09:36 PM
That seems pretty high for a relay does radioshack have them? it would be a lot cheaper and there meant for auto use anyway. just dont have that nifty plastic piece on the top to mount it somewhere, If its the same basic relay im thinking about otherwise the junkyard is your friend when it comes to parts like that. Everytime i go i load up on fuses, Bulbs, ext just fill my pocket with them while i walk out. Priceless
Old Aug 29, 2004 | 09:42 PM
but still the fan should still be runnning....
Old Aug 29, 2004 | 09:45 PM
No, Why would you think that? if the car is off the fan will not run. period. The car needs to be in the on position or run,
Old Aug 29, 2004 | 10:47 PM
most hondas that i have seen have there fan on when the key is off....it just to reduce the heat of thwe rad and fluids
Old Aug 31, 2004 | 07:54 AM
xsellxoutx's Avatar
Default Re: fan wont turn on... (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">how do you know the relay is good? </TD></TR></TABLE>
i swapped it with the a/c fan relay and the a/c fan still worked....
Old Aug 31, 2004 | 08:14 AM
allbottledup's Avatar
well if worse comes to worse rewire you fan. Either run it to a toggle switch and flip it on when your running or you can wire it to and acc item that will turn on and off with the car. At least you wont have to worry about overheating, and it will buy you some time to trouble shoot the problem.
Old Aug 31, 2004 | 08:34 AM
jolt-tsp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic92Turbo &raquo;</TD></TR><TR><TD CLASS="quote">most hondas that i have seen have there fan on when the key is off....it just to reduce the heat of thwe rad and fluids</TD></TR></TABLE>
I think that was only 01+ or something. My 03 Hybrid left the fan on after the car was off for a few minutes.
Old Aug 31, 2004 | 08:41 AM
rusted_eyes's Avatar
Default Re: (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">No, Why would you think that? if the car is off the fan will not run. period. The car needs to be in the on position or run, </TD></TR></TABLE>
No the fan should still stay on even after the ignition is turned off, if the car is still to warm. It's a safety feature so your motor doesn't overheat!
Old Aug 31, 2004 | 01:06 PM
Default Re: (NA_B16a2)
Ummmm NO it will not run with the key not in the car. Trust me i just got looking at two differnt wiring diagrams for a car with and w/o Ac and BOTH cars show the system CLEARLY going thro the ******* key switch! so stop argueing with me you you damned noobs!
Old Aug 31, 2004 | 01:14 PM
154 days as a member
Why don't you go jump off a bridge you Noob!
Old Aug 31, 2004 | 05:24 PM
I got a better idea, why dont you kiss my a$$ you idiot. Just because youve been a member longer then me dosent mean you know more then me.
Here is the Diagram. You see that thing in there called an Ignition switch, Come on say it with me here, Ig-nit-ion switch. Aka the thing where you put the key in when you start the car. With me so far or should i re-draw the pic for you with some jumbo crayons so you understand me. See its clearly in the circuit that controlls the Cooling Fan! So dont tell me i dont know what im talking about.
Btw for the guy who originally made this thread this should help you track down your problem in no time. sorry it took me so long to post it. Ive been dealing with ppl who think they know everything.
Old Aug 31, 2004 | 05:40 PM
jok's Avatar
jok
not to get in on a fight, but just to let you guys know my fan doesn't turn on when the key is out and in my pockets. It is because of the year make and model of my car.
We don't know what type of car his is, and different years are well DIFFERENT.
