doing compression test
Old Aug 28, 2004 | 06:05 AM
Cyber ITR's Avatar
Default doing compression test
im thinking to do compression test tomorrow on my spare time.
i just wondering do i have to pull any plug out to stop the injectors from dumping fuel while i put the car on WOT ?
and what sort of compression should be getting from a JDM ITR engine ? 11.2:1 CR i believe , 96-spec , done 130,000km
thanks guys
Old Aug 28, 2004 | 06:07 AM
DragII's Avatar
25 Year Member
Default Re: doing compression test (Day Walker)
just pull the ecu fuse...if you don't you might have a nice 130 bill for a new ignitor w00t!
Old Aug 28, 2004 | 06:56 AM
mugenracer's Avatar
Default Re: doing compression test (.D2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .D2 &raquo;</TD></TR><TR><TD CLASS="quote">just pull the ecu fuse...if you don't you might have a nice 130 bill for a new ignitor w00t!</TD></TR></TABLE>
Yep stupid me made that mistake with my last teg...there was almighty pop like a back fire and ignitor was toast
Old Aug 28, 2004 | 07:08 AM
Chubz's Avatar
Default Re: doing compression test (mugenracer)
you should be around 240-270 in all cylinders for the JDm motor. I hit 270-275 no problem.
Old Aug 29, 2004 | 04:28 AM
Cyber ITR's Avatar
Default Re: doing compression test (Chubzilla)
how many times do you have to crank it though ???
Old Aug 29, 2004 | 06:05 AM
uncleben's Avatar
I just did this on the race turd yesterday (90 Civic, took a dump in cylinder 4 at Mid Ohio it looks like)... Anyway, you just crank it until the needle on the compression gauge stop rising. At least, that's what I was told to do
I was also told to pull the blue and black/yellow wire connector on the distributor before cranking it over as well, would this work on our ITRs too? I haven't even looked yet.
Old Aug 29, 2004 | 09:08 AM
splitime's Avatar
Default Re: doing compression test (uncleben)
The process I use is this:
Pull all spark plugs (lowers the work load on the starter since no cylinder builds compression except the one being tested)
Pull the ECU fuse in the engine bay box (kills ignition and fuel)
Drop your comp tester in
Get in car and hit gas pedal to WOT
Crank away, usually takes 5+ to get a good reading.
Old Sep 16, 2004 | 10:51 AM
Audi RS4's Avatar
Lover
Default Re: doing compression test (splitime)
I understand all but the "be at WOT" when performing the test, Can someone explain?
Old Sep 16, 2004 | 11:26 AM
vtec.dc2's Avatar
Default Re: doing compression test (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">WOT</TD></TR></TABLE>
wide open throttle = pedal all the way down to the floor
Old Sep 17, 2004 | 01:26 PM
spankey167's Avatar
What fuse reading does the ECU fuse have? For exmaple 15a, 20a... would it be hard to locate? Or is it one of those huge fuses? i am wanting to do a compression test on a car before i purchase it today. So basically what fuse should i be looking for? Im not too familiar with an eg but im assuming that the fuse cover should tell me that right?
Old Sep 17, 2004 | 02:50 PM
Audi RS4's Avatar
Lover
Default Re: doing compression test (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
wide open throttle = pedal all the way down to the floor</TD></TR></TABLE>
I know what WOT is, I was wondering why you needed to be at WOT to do the test?
Old Sep 17, 2004 | 03:42 PM
DragII's Avatar
25 Year Member
you won't get true readings w/ throttle closed because hardly any air is getting into the chamber. at least thats my theory, my #s are way lower when testing w/ throttle closed.
Old Sep 17, 2004 | 03:49 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .D2 &raquo;</TD></TR><TR><TD CLASS="quote">you won't get true readings w/ throttle closed because hardly any air is getting into the chamber. at least thats my theory, my #s are way lower when testing w/ throttle closed.</TD></TR></TABLE>
Yes, that is true...you must be at WOT during compression testing. No more than 5 cranks of the engine is the usual amount.
Must be at WOT to ensure proper cylinder fill.
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
GSR_hatch936
Apr 5, 2007 11:04 AM
snowblind7x
Apr 13, 2005 08:12 PM
fafsa
Dec 3, 2004 08:15 PM
ITR77
Mar 11, 2004 11:01 AM
