Controlling Boost
Old Dec 4, 2001 | 06:40 PM
Cyrio's Avatar
Default Controlling Boost
Is it possible to safely keep boost from a turbo down to about 5 psi? If someone wanted to have the added power of a turbo, but not add too much stress on the engine, sorta like a supercharger, how would he/she go about doing this? Just a boost controller?
Old Dec 4, 2001 | 06:45 PM
GSR_Dude's Avatar
Default Re: Controlling Boost (Cyrio)
The boost is normally controlled by the wastegate. If you want to keep boost relatively low, then get a lower spring rate. I have a Tial 6.5PSI wastegate, therefore the lowest boost i can go is 6.5psi. The boost controller would only be used to up it from that rate. When I 1st got my turbo, I was only using the wastegate to regulate the boost and it felt o.k, but nothing spectacular. I added a manual boost controller, keeping the same PSI setting, boost hit harder and much much nicer. As for a supercharger, boost is controlled by the size of the supercharger pulley.
Old Dec 4, 2001 | 06:47 PM
Cyrio's Avatar
Default Re: Controlling Boost (GSR_Dude)
Thanks... when i mentioned the super, i was referring to the amount of boost. Are there wastegates out there that can allow you to boost as low as 5 lbs?
Old Dec 4, 2001 | 07:00 PM
GSR_Dude's Avatar
Yeah, the Tial brand comes in 4.5psi, 6.5psi and higher. Just do a search on Tial and see what it brings up.
nychonda
Jul 1, 2009 04:37 PM
turbo95eg6
Jun 12, 2005 12:15 PM
MachAF
Jun 27, 2003 05:14 PM
Snafu-Si
Mar 5, 2002 02:07 AM
SIK IN DA HED
Sep 13, 2001 03:16 AM
