Brake Fluid Leak - Please help!
Old Aug 27, 2004 | 08:07 PM
Rhythm's Avatar
Default Brake Fluid Leak - Please help!
I started this in the tech section with no responses, so I thought I would try here. Please help!
https://honda-tech.com/zerothread?id=972628
Thanks
Old Aug 27, 2004 | 09:30 PM
BatuKing's Avatar
Default Re: Brake Fluid Leak - Please help! (Rhythm)
do you see it in the pic/
http://www.hondaautomotivepart...7.gif
Old Aug 28, 2004 | 03:39 PM
Rhythm's Avatar
Thanks for the pic, but I don't think I see it. It is a small rubber piece that fits in the prop valve itself.
Old Aug 28, 2004 | 11:47 PM
BatuKing's Avatar
Default Re: (Rhythm)
Yes part # 40 right? infact take a picture and post it
Old Aug 29, 2004 | 08:30 PM
Rhythm's Avatar
Default Re: (BatuKing)
Thanks for your help BatuKing...
Here's a pic. The yellow line points to the hole the rubber piece fits into. If anyone has an old prop valve that doesn't work, please let me know if I can get this piece.
Thanks
Old Sep 26, 2004 | 08:48 PM
Rhythm's Avatar
I ended up buying a 4040 prop valve. My problem now is that the brackets are different. The bolts that hold the bracket to the prop valve have torx heads, but there is a small bump in the middle that keeps a regualr torx head from removing the bolt. Is there a special tool that I need to get these off? Please help if you can.
Thanks
Old Sep 26, 2004 | 08:58 PM
JDMlyfestyle's Avatar
those are safety torx. you can get those tools at sears or harbor frieght
Old Sep 26, 2004 | 09:32 PM
Rhythm's Avatar
Default Re: (JDMlyfestyle)
Thanks JDMlyfestyle
Old Dec 17, 2004 | 04:24 PM
mingbling96's Avatar
hey.. my prop valve is doing the same thing too.. but i have the rubber thingy still on there. but leaks when i bleed the brakes. what do i do?
jdm inc
Oct 30, 2010 11:41 PM
jdm inc
Oct 30, 2010 11:40 PM
fv8s
Sep 30, 2010 10:13 AM
Colin
Suspension & Brakes
Sep 29, 2009 11:20 AM
Rhythm
Sep 3, 2004 10:08 AM
