chassis to lca bolt will not go back in
like the title says. I can get the bolt through the non threaed hole but after that it wont line up with where it is supposed to come out. Any ideas or tips would be nice.
I figured it wasnt lined up. After it get it through I just cant seem to push or pull it in a way to where the bolt meets the thred
loosen up everything that is attacted to the LCA.....back it off one or 2 full turns each bolt you should be able to move it around then
spidermancivic
Aug 11, 2007 08:17 AM
