After installing obd-1 GSR cluster, Gas Gauge doesn't work-- help.
Old Aug 27, 2004 | 06:54 AM
integranator's Avatar
Default After installing obd-1 GSR cluster, Gas Gauge doesn't work-- help.
hey guys, a while ago I installed a 94 GSR cluster in my 98LS. Immediately after turning the car on, the needle which was previously on 1/2 full, buried itself way past "E". I haven't taken the cluster back out to see what the problem is, too much effort Do you guys recommend filling up, the pushing the needle to the "f" line?? Or move it back to the "E" level so it will recalibrate itself? Let me know what you think.
Old Aug 27, 2004 | 07:00 AM
mmuller's Avatar
Mad Scientist
Default Re: After installing obd-1 GSR cluster, Gas Gauge doesn't work-- help. (integranator)
There is a wiring difference between the 1994-97and 1998-01 Acura Integra's gauge cluster.
Here is a wiring layout of the 1998-01:
1>16=left to right
01=yellow/white=fuel gauge unit
02=light green/red=door-open indicator light
03=
04=blue/white=low fuel sensor
05=
06range=maintenance reminder light/tcm/ecm/cruise control unit
07=green=tailgate-open indicator light
08=red/blue=seat belt reminder light/driver's seat belt switch
09=red=dash brightness controller
10=red/black=fuse for gauge light
11=black/yellow=charging system light
12=white/green=hazard warning light
13=green/blue=left turn signal switch
14=green/yellow=right turn signal switch
15=red/green=fuse for high beam indicator light
16=green/red=brake system light/parking brake switch
here is the 13 pin layout.
1>13=from left to right.
01=pink=hazard warning light>harzard warning switch
02=pink=maintenance reminder light>maintenance reminder unit
03=
04=yellow/blue= fuse?
05=red/blue=cruise control unit/light
06=black
07=yellow/green=engine coolant temperature gauge(ect)
08=
09=white/blue=charging system light>alternator
10=
11=yellow/red=low engine oil pressure indicator light>engine oil pressure switch
12=green/orange=malfunction indicator lamp
13=blue=ignition control module>tachometer drive unit
1994-97
B1 = seat belt reminder
B2 = door open indicator
B3 = fuel gauge unit
B4 = low fuel light
B5 =
B6 = speedometer drive circuit
B7 = hatch (trunk) open indicator
B8 = abs indicator light
B9 = gauge lights (from fuse)
B10 = gauge lights (from dimmer)
B11 = charging system light (from battery)
B12 =
B13 = left turn indicator
B14 = right turn indicator
B15 = high beam indicator
B16 = parking brake light
D1 =
D2 = maintenance reminder
D3 =
D4 = cruise control (from fuse box)
D5 = cruise control (from cruise control unit)
D6 = ground for high beam indicator
D7 = coolant temp gauge
D8 =
D9 = charging system light (from alt)
D10 =
D11 = low oil indicator
D12 = malfunction indicator
D13 = tachometer driver circuit
Old Aug 27, 2004 | 07:12 AM
Default Re: After installing obd-1 GSR cluster, Gas Gauge doesn't work-- help. (mmuller)
What do u suggest I do?
CTR_B
Mar 20, 2008 09:47 AM
IntegraGSR311
Jun 21, 2006 09:22 PM
CL1accord
Jun 24, 2005 09:59 AM
speedracex
Jul 27, 2004 05:00 PM
crooked muffler
Jan 21, 2003 11:31 AM
