Ignition Coil Negative Pickup
Old Aug 27, 2004 | 12:23 AM
vtecist's Avatar
Default Ignition Coil Negative Pickup
Hi, i'm trying to find the negative side of the coil on a 95 2.2 Prelude so i can wire a RPM monitor to it, does anyone know where the best place is to pick this up? I've read some people say you can get it from the ECU but i don't know the PINOUT config of the ECU. Any ideas anyone?
Old Aug 27, 2004 | 02:09 AM
@ries's Avatar
Default Re: Ignition Coil Negative Pickup (vtecist)
What RPM monitor device are you actually trying to install? Well heres a pinout for the RPM signal on the ECU...
Old Aug 27, 2004 | 02:32 AM
vtecist's Avatar
Default Re: Ignition Coil Negative Pickup (@ries)
I'm fitting a clifford remote start system that needs to monitor the RPM. That image helps loads, thanks mate.
DanB93
13
Dec 9, 2013 06:53 AM
project civic
May 12, 2005 06:54 AM
jtracing919
Jan 11, 2005 06:41 AM
blufke
Mar 1, 2003 12:31 PM
