Skun2 manifold = more vibration?
Old Aug 26, 2004 | 07:29 PM
monicle's Avatar
Default Skun2 manifold = more vibration?
I jsut got done installing my new Skunk2 manifold and Hondata manifold gasket and I have a noticeable difference in vibration, especially in the pedals for some reason. Is this because the Skunk2 manifold sits higher than stock? Im not really worried about it cause the car runs like a champ. I was just wondering if anyone else had similar results.
Old Aug 26, 2004 | 07:37 PM
murmur9's Avatar
Default Re: Skun2 manifold = more vibration? (monicle)
dont worry about it, im sure it has something with the weight distribution...different from oem right.....
hayabusa160's Avatar
is the throttle cable touching the firewall?
mines is and thats why i get crazy vibrations
Old Aug 26, 2004 | 08:00 PM
dinosa21's Avatar
Default Re: Skun2 manifold = more vibration? (hayabusa160)
Make sure you tighten the bolts on the manifold after driving around for awhile. Just to make sure they stay tight.
Old Aug 26, 2004 | 08:04 PM
TeStUdO's Avatar
Default Re: Skun2 manifold = more vibration? (dinosa21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dinosa21 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you tighten the bolts on the manifold after driving around for awhile. Just to make sure they stay tight.</TD></TR></TABLE>
Also make sure all your vacuum hoses are on tight. Is your idle any different?? A vacuum leak and a lower idle could make for a lopey vibrating idle.
Old Aug 26, 2004 | 08:31 PM
Quad-Damag's Avatar
Default Re: Skun2 manifold = more vibration? (TeStUdO)
sometimes u have to xtend ur studs bebecuase the manifols isn't as well on, due to the bigger gasket such as the hondata gasket
Old Aug 26, 2004 | 09:25 PM
monicle's Avatar
actually I think the throttle body is slightly touching the hood which might be it. I need to replace the bracket so that it sits lower.
Old Aug 26, 2004 | 09:30 PM
CivicFerioSiR's Avatar
sohc or dohc?
Old Aug 26, 2004 | 09:38 PM
TeStUdO's Avatar
Default Re: Skun2 manifold = more vibration? (CivicFerioSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR &raquo;</TD></TR><TR><TD CLASS="quote">sohc or dohc?</TD></TR></TABLE>
wel his signature says B18C so im guessing dohc
Old Aug 27, 2004 | 03:46 AM
monicle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
wel his signature says B18C so im guessing dohc</TD></TR></TABLE>
djnikko
Feb 6, 2006 02:03 PM
Red_ED8
Jan 14, 2006 11:47 PM
nebulight
Nov 13, 2004 01:44 PM
Mark
Nov 20, 2003 12:30 PM
