Ignition timing adjusting connector
Old Aug 26, 2004 | 05:12 PM
gooser's Avatar
Default Ignition timing adjusting connector
1990 Civic Hatch 1.5L
Where is the "Ignition timing adjusting connector"? I am trying to adjust the timing and the book says I need to connect a jumper to this...
and ... Why?
Old Aug 26, 2004 | 05:14 PM
Apocolipse269's Avatar
Default Re: Ignition timing adjusting connector (gooser)
try looking at the distributor, the wires that plug into it that go to the spark plugs
Old Aug 26, 2004 | 05:15 PM
Deemeetree's Avatar
Electrician
It's under your carpet where the ECU is. You'll see a 2 pin connector, you'll need to jump this. I didn't know this was also needed in pre-1992 models. Aren't those OBD-0? Nonetheless, you need to jump the service connector so the ECU won't try to place the timing where it was after you adjust it. At least it's this way for 1992+ so it might be the same with 1992 and older. Not sure but it sounds the same. Don't quote me. Plus, you're in the wrong forums. This is 1992+.
Old Aug 27, 2004 | 08:51 AM
gooser's Avatar
Default Re: (Dimi)
Thanks very much! The book was not specific and it also referred to the SAME location as 1992+, but NEVER told me where it was!! Darn Haynes Manual...
Old Feb 13, 2005 | 04:19 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (gooser)
Bump, where is this connector in an EG hatch? By the ECU?
Old Feb 13, 2005 | 08:45 PM
ejprimo's Avatar
Default Re: (LSVTEC 91 Civic)
its a blue connector that should be to the right of the glove box above the ecu. and i usually bend a paper clip and use that to jump the connector.
jwarren1904
Feb 9, 2014 03:17 PM
JohnnyEF
Feb 10, 2010 06:09 PM
Daniel
Aug 22, 2003 07:05 PM
JdmIntegra98
Jul 2, 2003 10:10 PM
Boostless97Lude
Jan 7, 2003 08:24 AM
