rear disc?
Old Dec 4, 2001 | 11:51 AM
brian.edge's Avatar
Default rear disc?
i am still new here and to the ef civic but in my time here i have learned alot and you guys have been great help. now i come to you again for help, i have read that you can do rear disc breaks on my 90 civ si how and what do i need to do this...
thanks guys and girls(trinty)
Old Dec 4, 2001 | 12:23 PM
rioninja's Avatar
Default Re: rear disc? (lilhibbs)
Find a CRX si at your local junkyard and take the rear disk setup from that. 89 and older integra rear disk setups will work as well, and are a lot more plentiful at your local u-pull-it. Pretty much everything will bolt on, but you will need different parking brake cables. There are probably a few other pointers people can give you.
Old Dec 4, 2001 | 12:38 PM
Piston_Honda's Avatar
New User
Default Re: rear disc? (RioNinja)
Will the same parts fit on an 88 crx si?
Old Dec 4, 2001 | 01:01 PM
JUNpoweredITR's Avatar
New User
Default Re: rear disc? (Piston_Honda)
Yep.
Peace...
Old Dec 4, 2001 | 01:07 PM
SiR Kid's Avatar
New User
hmmm 86 89 integra rear brakes work on the 89-91 hatch? I've got 93 integra Brakes on mine, and besides the weird offset issues <I THINK caused by this> they work great even with the integ Cables!
Old Dec 4, 2001 | 01:22 PM
JohnnyM's Avatar
Default Re: rear disc? (SiR Kid)
Here you go... All you need and hot to do it.... http://www.geocities.com/CapitolHill.../Disc2Drum.htm
Old Dec 4, 2001 | 05:15 PM
89HF's Avatar
New User
90-93 Integra r brake hubs will bolt to your trailing arms,so your offset won't change.
Old Dec 4, 2001 | 05:50 PM
rioninja's Avatar
Default Re: rear disc? (DOHC DX)
86-89 rear discs DO NOT WORK on 88-91 hbs/crx...
totally different trailing arm...
ANYTHING 90 and up WILL bolt in...
I've heard otherwise countless times, but i never tried it myself (already have disc). I'm gonna stand corrected since i'm gonna assume you've done it. Sorry for any mis-information people
Old Dec 4, 2001 | 09:45 PM
BIG RICH's Avatar
The 86-89 integra's have solid rear axles, like the first gen. crx's.
[Modified by BIG RICH, 10:46 PM 12/4/2001]
Old Dec 5, 2001 | 05:30 AM
ODX's Avatar
ODX
New User
Default Re: rear disc? (JohnnyM)
thanxs Johnny M your web page was very helpful. I am going to get my rear disks today from the wreckers from a 92 integra. Everything I need all for a $100!!! Thanxs
Old Dec 5, 2001 | 09:42 AM
jaje's Avatar
Default Re: rear disc? (ODX)
get the teg's parking brake mechanism too!...you'll have to creatively run the wires (they are longer than the ef's) but they will work easily
Old Dec 5, 2001 | 11:07 AM
SiR Kid's Avatar
New User
Default Re: rear disc? (jaje)
Uh, my cables were exactly the same length... from a 93 integra. I ran em JUST LIKE STOCK, and they lined up everywhere perfectly.
Old Dec 5, 2001 | 05:19 PM
Giuseppe's Avatar
yeah mine lined up perfect too!!
no 'creative' e-brake setup here..
bolted up like stock!!
I used 91 teg rear disk.. on my 90
HTH
Old Dec 5, 2001 | 05:47 PM
Mugen Dom's Avatar
Default Re: rear disc? (Giuseppe)
they are longer but if u run the cables right u can put them up easily they arent like a lot longer just a little
Old Dec 6, 2001 | 06:26 AM
SiR Kid's Avatar
New User
Default Re: rear disc? (jdmB18hatch)
Sooo is it a fact that since I bolted up the teg control arms and all, my alignment, toe and all in the rear s going to be fucked til I put Civic trailing arms and control arms and all back under it?
alx_90ef
May 24, 2009 06:52 AM
yellowjdmcrx
May 7, 2006 01:14 PM
BOSS-REX
15
Oct 2, 2004 03:56 PM
SilverDc2
Sep 10, 2003 04:37 PM
CRX SiR T
Jul 1, 2003 12:19 PM
