Crazy problem...NO codes!
Old Aug 26, 2004 | 12:26 PM
Superhatch's Avatar
Default Crazy problem...NO codes!
So I have this electrical problem. When under load (mainly when driving, accentuated with lights on and more with high beams on) my tach bounces with my blinkers, and my temp and gas gauges go a bit crazy. It wont happen when I'm sitting still, only when in motion. Alternator is good, dizzy is good, JUST put new grounds on it today (battery, and valve cover, re-checked engine harness ground). Problem persists.
A Honda tech said ELD. I swapped a known good ELD...no change.
ANY ideas would be greatly appreciated...
-Jake
Old Aug 26, 2004 | 12:30 PM
spaceman's Avatar
Default Re: Crazy problem...NO codes! (Superhatch)
any blown fuses? is everything wired up correctly? try resetting your ecu anyways and maybe you will get something
Old Aug 26, 2004 | 12:31 PM
4drEF's Avatar
Keyboard Humorist
any mods?
Old Aug 26, 2004 | 12:46 PM
Tyson's Avatar
clean the contacts on the back of your guage cluster. worked for me.
Old Aug 26, 2004 | 01:23 PM
Superhatch's Avatar
Default Re: Crazy problem...NO codes! (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">clean the contacts on the back of your guage cluster. worked for me.</TD></TR></TABLE>
Ill give that a try.
D16a6 w/ I/H/cat/E, bored TB, lsd, flywheel.
The fuses are all good, and the wiring is perfect in the engine bay, my underdash harness was hacked for an alarm by the previous owner, but I've never had any problems with that.
Old Aug 26, 2004 | 01:26 PM
daidilus's Avatar
yeah check the wires to the cluster...when i swapped my cluster..i got the ground wire 1 pin off, and what are you are talking about happened to me also.....so you may want to double check all your wires, and clean the contact points..
Old Aug 26, 2004 | 01:37 PM
fourthgenhatchB17's Avatar
Default Re: Crazy problem...NO codes! (daidilus)
Whats ELD? Electronic Load Detector? Where is that located...
Old Aug 26, 2004 | 03:51 PM
Superhatch's Avatar
Default Re: Crazy problem...NO codes! (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Whats ELD? Electronic Load Detector? Where is that located...</TD></TR></TABLE>
Its located in the passanger side fuse box, under the hood. Its a little black box, inside the fuse box. Sorry...couldnt find a pic.
Old Aug 26, 2004 | 09:10 PM
Superhatch's Avatar
I'm in awe.....after motnths of chasing this problem all over my car...the cluster just needed a cleaning.
A small brush, and some rubbing alchol...done. Tyson...you are a Hero.
Old Aug 26, 2004 | 09:20 PM
Tyson's Avatar
werd.
DomonicCB7
Apr 9, 2015 07:38 PM
bwindsor
Apr 29, 2013 06:19 AM
Azn Mug3N (01 em2)
Honda Civic (2001 - 2005)
12
Jan 1, 2007 04:51 PM
dohcguy
Oct 26, 2006 06:00 PM
budget
Jun 18, 2006 08:22 AM
