HELP ME!!! Pulling codes 71, 72 , 73, 74 on a 98 civic
Old Aug 26, 2004 | 12:02 PM
RELprojects's Avatar
Default HELP ME!!! Pulling codes 71, 72 , 73, 74 on a 98 civic
To make a long story short well, first i got a code 90 which was gas leak and after i fixed that i warmed up the car and the idle jumps around to 200 - 1000 - 500 basically it wasn't steady like how it was before so check the codes and got a code 71, 72, 73, 74 which is misfiring in cylinders 1, 2, 3, 4. what do i do now?? is the ecu messed up??? all the wiring is fine and plugs and caps is all in order because i tripple checked it
NEED SOME DEPREATE ADVICE IN HOW TO GO ABOUT SOLVING THIS PROBLEM...................................
Old Aug 26, 2004 | 12:18 PM
Default Re: HELP ME!!! Pulling codes 71, 72 , 73, 74 on a 98 civic (JDMspecs Eg6'er)
ttt!
Old Aug 26, 2004 | 05:30 PM
ttt
Old Aug 26, 2004 | 06:17 PM
TurboEH2's Avatar
are u positive u have the correct wiring scematics on how the plug wires go on the dist?
Old Aug 26, 2004 | 06:52 PM
JDMlyfestyle's Avatar
are the plugs gapped correctly?
is the firing order correct?
plug wires good?
spark plugs good?
dizzy cap good?
Rotor good?
Old Aug 26, 2004 | 07:19 PM
everything is good.................. the whole misfiring started when i had to check for a code when i got a code 90 then i accidently left the jumper wires in the service connector and thats when the new codes began........
Old Aug 26, 2004 | 07:30 PM
hmm thats wierd i never heard of a code 90? any one else?
Old Aug 26, 2004 | 08:24 PM
Default Re: (JDMlyfestyle)
here is the code 90 its for a 1998 civic lx
http://www.geocities.com/honda_club_egypt/ecu.htm
EK_vzla
Aug 30, 2004 01:39 PM
DriveSideWays
Aug 18, 2004 07:27 PM
civickid99
May 8, 2004 12:15 PM
XSSIVE
Nov 21, 2003 06:54 PM
Babybluegsr92
Jan 19, 2002 08:17 AM
