fuel reg.
hey guys,
my fuel pressure regulator is bad(i think) it doesnt hold pressure anymore well lets it out slow
i was thinking of replacing it with a B&M regulator set up polished so it doesnt look all different for the cops bc around ppl get sent to the ref for one here
my question is waht do u think of and past experiance with B&M? or go with a different one or just stay with stock
whats your set up...do you have any reason to get a adjustable one??? if your set up doesn't require adjusting you fuel pressure there is no reason to vary from stock.
If your stock regulator is bad (though it doesn't necessarily sound like it from your description), buying a B&M unit won't help you. The B&M requires you to modify your stock regulator for installation, so if the stock piece is broken, the B&M will be too.
You should just get a cosmo racing fuel pressure regulator.
Because it comes with the gauge as well.
And it's all one piece, rather than trying to buy a gauge and installing it.
The b&m gauge sucks anyways the bolt that connects to the filter always break ahhaha.
deadazleep
Nov 7, 2009 09:33 AM
Mr.EM1
Jan 6, 2005 11:17 AM
