pr3 or p30 pistons for b16 all motor???
Old Aug 25, 2004 | 10:34 PM
kenepo_vtec's Avatar
Default pr3 or p30 pistons for b16 all motor???
I HAVE A CRX WITH B16A , BUT I HAVE USDM ITR PISTONS ON IT! I NEED TO KNOW WICH PISTON WILL MAKE MORE POWER...(PR3 OR P30)
I RAN 14.00 IN 1/4, BUT I WANT TO KNOW IF I CHANGE THE PISTONS FOR A PR3 OR P30 WILL RUN LOWEST TIMES???
Old Aug 25, 2004 | 10:54 PM
anothersickhatch's Avatar
Default Re: pr3 or p30 pistons for b16 all motor??? (kenepo_vtec)
theres really not a big difference between those pistons. the jdm b16 pistons are 10.4:1 compression and the usdm b16 pistons are 10.2:1. get some ctr pistons and boost that compression up to 11, then youll see some real results.
they are either 10.4 or 10.2 so there is a mild difference in power that you are going to get.
Old Aug 25, 2004 | 11:06 PM
Default Re: pr3 or p30 pistons for b16 all motor??? (anothersickhatch)
WHAT I NEED TO PUT IN CTR PISTONS ON B16A...ANY MODIFICATION TO THE HEAD OR WHAT????
LET ME KNOW I'M VERY INTEREST!!!!!
Old Aug 26, 2004 | 12:34 AM
like i said, as long as you have good fuel management to handle the high compression, you can put ctr's in a b16 with no problem. good power gains.
i already went through two sets because of running too lean, so make sure you get it tuned.
jap305
Jan 3, 2012 03:33 PM
1993gsrcivic
Oct 3, 2007 11:31 AM
crxowner
Jul 26, 2005 05:57 PM
KillaB-
Sep 19, 2004 06:01 PM
rcurry14
10
Aug 6, 2004 08:36 PM
