PROBLEMS WITH MY B16 LSD TRANNY
Old Aug 25, 2004 | 07:28 PM
boostng r's Avatar
a
Default PROBLEMS WITH MY B16 LSD TRANNY
ok i got a b16 lsd tranny in my car its been shifting fine all of a sudden the next day its hard to get it in all the gears
it shift fine while the car is off and when the clutch is in when the car it is off i been running the gm oil
could this be a clutch problem of inside the tranny
and i have not raceed my car like in 1 month
Old Aug 25, 2004 | 07:32 PM
boostng r's Avatar
a
tttt
Old Aug 25, 2004 | 07:33 PM
Deemeetree's Avatar
Electrician
Hard to get into the gears as in grinding while going into a gear or as in you can't place the shifter in ANY gear?
Old Aug 25, 2004 | 07:37 PM
boostng r's Avatar
a
it grinds sometimes when i try to put it in gear but it will let me select the gears but it verry hard to put it in gear
Old Aug 25, 2004 | 07:45 PM
Deemeetree's Avatar
Electrician
Have you checked the condition of your shifter bushings? It's sometimes the simple stuff that causes the most headaches.
boostng r's Avatar
a
Default Re: (Dimi)
they are brand new energy bushings
Old Aug 25, 2004 | 07:47 PM
Kamin's Avatar
Default Re: (b16coupe4)
check fluid level.
also physically get under the car and look at the bushings, dont just say they are new. one could have come out.
Old Aug 25, 2004 | 07:48 PM
boostng r's Avatar
a
fluid level is perfect the bushings are perfect
anything else
Old Aug 25, 2004 | 08:00 PM
boostng r's Avatar
a
ttttttttttttt
Old Aug 25, 2004 | 08:02 PM
backdraft's Avatar
It is probably your clutch taking a ****. If all the other stuff the others said is cool. This may be the problem solver.
Old Aug 25, 2004 | 08:04 PM
boostng r's Avatar
a
ok cool i just hope its not the inside of the tranny
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 &raquo;</TD></TR><TR><TD CLASS="quote">ttttttttttttt</TD></TR></TABLE>
DUDE stop bumping your thread every 10 minuets. if someone can help they will find it. if the fluid, linkage and bushings are good its the clutch.
if it only happened in 1 gear it would be the trans, if its all of them odds are its the clutch.
Old Aug 25, 2004 | 08:11 PM
xerox445's Avatar
Default Re: (Kamin)
10 bucks your pressure plate is shot
Old Aug 25, 2004 | 08:12 PM
boostng r's Avatar
a
ok thanks and sorry for trying to find out whats wrong with my expensive *** tranny
Old Aug 25, 2004 | 09:38 PM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks and sorry for trying to find out whats wrong with my expensive *** tranny </TD></TR></TABLE>if its so expensive and precious go take it to a profesional
i say its your fluid. my .02
Old Aug 25, 2004 | 11:03 PM
boostng r's Avatar
a
i already check it its perfect and for profesionals thats what honda tech is here for i know how to do the work
Old Aug 25, 2004 | 11:10 PM
_BEN_'s Avatar
Have you bled the clutch mc?? Maybe there is just not enough fluid to compress the pressure plate.
If its not that its probably your pressure plate.
Old Aug 25, 2004 | 11:11 PM
boostng r's Avatar
a
Default Re: (_BEN_)
thanks i already check that i am gonna change the whole clutch everything brand new
lacking vtec
Mar 29, 2007 03:29 AM
AzntstyleZ
Jun 27, 2005 08:21 AM
B16X
Aug 11, 2004 06:35 AM
underpressure02
May 11, 2004 07:29 AM
rex_boy
Mar 17, 2003 11:08 AM
