wheel bearing/rotor swap
I've heard that you could use wheel bearings, and rotors from a CL. Problem is I don't know which one ( CL ), I need parts from. If anyone has knowledge of this, Help me. P.S. It's so I can just take 30 min and change rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmj88hb »</TD></TR><TR><TD CLASS="quote"> I've heard that you could use wheel bearings, and rotors from a CL. Problem is I don't know which one ( CL ), I need parts from. If anyone has knowledge of this, Help me. P.S. It's so I can just take 30 min and change rotors.
Your actually still using Accord wheel bearings and CL hubs.
Here a two threads from AccordinglyDone that explain the conversion.
http://www.accordinglydone.com...=3970
http://www.accordinglydone.com...=1177
Hope this answers your questions.
</TD></TR></TABLE>Your actually still using Accord wheel bearings and CL hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsintegra9 »</TD></TR><TR><TD CLASS="quote">im intrested in this to becuse the whole rotor behind the wheel bearing thing sucks</TD></TR></TABLE>
The bearing is actually behind the rotor and the rotor is behind the hub, hence hub-over-rotor.
Anyways, check those links I posted and you should get all the info you need.
98-99 2.3 CL bearings are the same. i highly recomend the conversion. if you don't mind used parts its much easier to just swap ovr the whole knucle from a 98-99 2.3 CL.
greenthumber
Jan 28, 2012 01:39 PM
nightrider
Jul 24, 2009 07:02 PM
hankd
Jun 20, 2005 05:19 PM
