CEL no V TEC any relation?
Old Aug 25, 2004 | 04:24 PM
type-t's Avatar
Default CEL no V TEC any relation?
i have a check engine light due to no oxygen sensor connected to the ecu...
"This question is only for those that no the correct answer...please dont assume"
will this cause my v tec not to kick in? and if not..what else can cause that? thanks
++++++++++++++++92' accord jdm h22a swap++++++++++++++++++++
Old Aug 25, 2004 | 05:05 PM
WuWarrior's Avatar
Default Re: CEL no V TEC any relation? (type-t)
Why are you so worried about the vtec?
A bad o2 sensor will cause not only bad emissions but poor performance as well.
Old Aug 25, 2004 | 05:28 PM
type-t's Avatar
Default Re: CEL no V TEC any relation? (WuWarrior)
i know it will like shiet but will this cause the v tec no to kick in? i test drove the car and it was pretty fast but i didnt feel the v tec
Old Aug 25, 2004 | 05:49 PM
type-t's Avatar
is the a code for the v tec not kicking in?
Old Aug 25, 2004 | 06:30 PM
type-t's Avatar
come one fellas help me out
Old Aug 25, 2004 | 06:59 PM
JDM.Accord's Avatar
Do you know for a fact that vtec isn't working or are you just going by what you feel/don't feel? You'd likely have a code if vtec wasn't engaging. Fix your O2 problem and see if you get another code.
Old Aug 25, 2004 | 08:37 PM
type-t's Avatar
Default Re: CEL no V TEC any relation? (JDMAccord2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAccord2nr &raquo;</TD></TR><TR><TD CLASS="quote">Do you know for a fact that vtec isn't working or are you just going by what you feel/don't feel? You'd likely have a code if vtec wasn't engaging. Fix your O2 problem and see if you get another code.</TD></TR></TABLE>
i will do...i'll post if the problem persist even after cleaning the CEL
MysteryWagon
Mar 10, 2005 08:07 PM
rammstein
Dec 18, 2004 01:17 PM
fsck3r
Aug 17, 2003 11:46 PM
E-spec Tuner
Jun 4, 2003 10:22 AM
6SPD_EK
Feb 20, 2002 02:52 PM
