pg7 rev limit?
On the pm7 its 7200
The pg7's i've had have had different rev limits. from 7500 to 7800.
If you see you hit rev limit before or after that keep in mind your tach could be off at those rpms sometimes. I have a chipped pm6 with no rev limiter on the program but I have an msd 6AL with the rev limiter at 7600 and when I hit rev limit, my tach is around 7400rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">the PG7 is 7519
per my VAFC</TD></TR></TABLE>
same here.....
this is correct.
same here.....
this is correct.
for some reason my pg7 redlines at 7000rpm. could something be wrong with it?
ive also looked at a 1st gen tegs guage cluster, the redline shows 7000rpm. would they put the fuel cut that much higher then the posted redline?
Does it redline at 7200 rpms when it fully warmed up? The reason I ask is my car will redline at 7200 when it initially running and not fully warmed up. Once its warmed up you can pull all the way to 7500.
BlackCivSi
21
May 4, 2004 08:24 PM
