True or False : The Bigger the rim, the lower the car?
Used to have hxs on azenis and they have never rubbed...but ever since i got the 15" mf10s w/ azenis they seem to rub more than the average civic. My drop are just Eibach Sportlines! WHY! Uneven pavement would cause like a slight rub against the fender....i hate driving fast on freeways. My shocks are totally blown...maybe thats the problem...sounds like i hit a landmine every time i hit a dip or a hole. *BBBOOOOMMM*
By the way is the answer true or false?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRizEJ6 »</TD></TR><TR><TD CLASS="quote">ummm....i believe thats false...</TD></TR></TABLE>
If you are talking the Azenis sports.....looks at the sizes...the 15" is slightly less in diamter but .5" wider.
http://www.falkentire.com/tires_rt215_sizes.htm
Bigger rims fill the wheel well, it doesnt lower the car (opposite actually). Also check the offset of the rims, might be rubbing 'cuz of that. They might stick out too much.
lol.. what kind of question is that? that has to be close to the top of the worst questions ever asked on honda-tech..
why dont you re-think that question.. then answer it yourself..
If you think about it, just divide your rim size by 2, and that's how high your car is off the ground from the axels+tire size... How can you ask this question....? The answer is pretty obvious... if you put 10" wheels on your car it would be really low... monster truck wheels would lift it really high.... get the idea?
ok this should solve your prob it did mine i have a 96 hatch and have 15 inch rotas with falken azanies and my hatch is slaaaaaaamed with skunk 2 coil overs i just grind off the lip on the inside of the fender off and then i never rubbed again just dont turn really fast like on a drive way going up at an angle then you will rub
It could also be rubbing because of the tire width. Like if before you were running 205's and now say 215's on the same wheel it might rub. If you were running 14's with 50 series tires and now 15's with 50 series your tires would "tuck" or just be a longer distance in diameter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote"> My shocks are totally blown...maybe thats the problem...?</TD></TR></TABLE> <~~~~`i think you answerd your ?..... check for leaks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaWorm »</TD></TR><TR><TD CLASS="quote">if you put 10" wheels on your car it would be really low... monster truck wheels would lift it really high.... get the idea? </TD></TR></TABLE>
that sounds bout right
dont forget to go by <U>overall diameter</U>, not just the rim size..
sorry bout that dent too
will my springs loose there elasticity or be ruined if i have them on stock struts?
my struts are ok now but with the ride height its at right now the struts will soon wear. will my springs as well?
Check this out, it's a tire wheel size calculator.
http://www.miata.net/garage/tirecalc.html
Spider Man
Sep 23, 2005 10:10 PM
