Headers & firing order
Old Dec 4, 2001 | 07:26 AM
teg92's Avatar
Default Headers & firing order
I haven't been getting any intelligent criticism / discussion in the integra forum, so I thought I'd show you this thread I've got started with no answers. Please check it out and throw in some input! (Discussion of the relevance of collecting order & fire order).
https://honda-tech.com/zerothread?id=95552
Old Dec 4, 2001 | 11:18 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Headers & firing order (teg92)
Try looking around (search function) on ENDYN BBS.
I know why the Hytech works better, but hard to explain, he is my shot at it though.........
The header makers think they are building a V8 design with 1-4 and 2-3 paired. The problem is with a 4 cyl the pulses end up too far apart. After #1 dumps out gases the pulse will have stopped and reversed by the time #4 dumps gases out. The 2 pulses meet which is not good for flow.
With the 1-3 and 2-4 pairing, #1 gas pulse will still be heading downstream when #3 dumps gases and will help scavenge it better.
Now the secondary tubes do the same for each other. The #4 and #2 pulse will scavenge the other secondary tube, which helps scavenge #1.
Hope this helps. I read about it 17 years in a V8 builders guide.
Just on of those things when you finally figure it out, you smack your head against the wall and go DUH!
I just don't have the $$$ for one of John's headers.
[Modified by Mista Bone, 8:19 PM 12/4/2001]
Old Dec 4, 2001 | 11:54 AM
teg92's Avatar
Default Re: Headers & firing order (Mista Bone)
Hmmm.. seems like some sort of travesty that I can find only 1 company that is building headers with a 1-4 2-3 arrangement!! Anybody know of any other companies than hi-tech that makes headers in this arrangement?
Though I think that there still has to be a good reason why all the companies are going in the manner they do! I wonder what DC Sports has to say on this. Probably "well we did dyno testing and bla", but I wouldn't believe it unless I saw another header with the 1-4 2-3 arrangement that makes awesome power...
Old Dec 4, 2001 | 01:51 PM
SjCiViCHB's Avatar
maybe its for emmission purposes...because the ol skool dc header where the o2 sensor was just reading one tube wouldnt pass smog, i dunno, im just taking aguess...
Old Dec 4, 2001 | 02:46 PM
Mista Bone's Avatar
D Tranny Guru
Ease of building and cost to build.
Old Dec 4, 2001 | 03:11 PM
teg92's Avatar
So you think all header manufacturers are just following whatever the guy before them did and scamming us out of a better product? Makes sense until you consider JUN.
Old Dec 5, 2001 | 01:46 AM
Mista Bone's Avatar
D Tranny Guru
takes alot or trial and error to perfect.
Do some research on ENDYN BBS. Alot of info is there.
BTW never said you had to purchase the products from them, but the info is dead on!
kulo
Welding / Fabrication
15
Aug 20, 2009 04:49 PM
dezerte
Oct 8, 2006 07:19 AM
dropped like its hot
Feb 22, 2006 11:23 AM
jokr78
15
Nov 16, 2004 11:58 AM
Toms96GSR
Jul 26, 2002 10:33 AM
