timing belt tension affect performance?
Old Aug 25, 2004 | 11:29 AM
handa's Avatar
Default timing belt tension affect performance?
like the title says, does the tension of the timing belt affect performance at all? mine is not too tight and not too loose...but i'm curious if i should tighten it up a little. thanks.
Old Aug 25, 2004 | 11:48 AM
Deemeetree's Avatar
Electrician
Well if it's too tight, it can rip apart under a good amount of force (dropping the clutch from a high RPM, taking it up to redline a lot, downshifting and allowing the engine to rev pretty high, etc...). If it's too loose, you can skip a tooth or 2 and THAT will affect performance since you will be either too advanced or too retarded. Serious bogging.
Old Sep 3, 2004 | 07:25 AM
Proglow3's Avatar
Default Re: (Dimi)
What's the spec's on deflection for the timing belt? I looked through my auto repair manual and didn't find anything. I believe that mine is too lose! I'm looking into replacing it but I need to know how tight it's supposed to be.
Old Sep 4, 2004 | 08:47 AM
Proglow3's Avatar
Default Re: (Proglow3)
Anyone?
Old Sep 5, 2004 | 08:04 AM
FermiumHalo's Avatar
My buddy is a honda technician and he taught me... I count back three teeth and then tighten. turn over the motor and check it. Mine is pretty tight like 1/4 inch deflection. I rev to 9200k and no problem....
Old Sep 8, 2004 | 08:43 AM
Proglow3's Avatar
Default Re: (FermiumHalo)
Thanks for the help...I ended up getting more spicific information from the honda dealership/Mech's.
Gsr97s
Jan 17, 2010 08:48 AM
5thGeneration
Nov 19, 2007 02:19 PM
BoM
Aug 6, 2001 06:03 AM
