short shifter PROs & CONs
what's a good short shifter for the crx ? does it make a difference what type of tranny you have ? pro's and con's to having one ?
just wondering what other benefits there are to having one beside being able to shift into gears faster.
I will just say don't get a shifter that is too short because this usually means increased effort when changing gears unless they move the pivot point for more leverage. You want something that is shorter than stock but still smooth. A notchy shifter probably takes longer or the same time to shift than a smooth one with a longer throw. If you do find that the shifter is too notchy you can extend the lever for more leverage by means of a height adjustable lever or simply weld on more metal.
yea that was one of my concerns thanks for the helpful info
by 'notchy' you guys are refering to the bends in the shifter right?
I don't understand why there's all this fuss about short shifters. It's simple:
1) There's a shorter throw
2) Since there's not as much leverage, yes, you do need to apply slightly more pressure. Unless you've got girly arms, there's no point in even discussing this point any further.
3) It's notchier.
4) Trannies/Syncros mess up because of a driver's inabilty to shift correctly. Don't blame it on a piece of steel/aluminum for your errors.
5) Bearing/bearingless. My SS doesn't have a bearing, but i did torque it down to the correct specs, which yielded stock shifter-like movement. Maybe a bearing SS might feel different, but if you're coming from a stock shifter, a bearingless one won't feel any different.
3) It's notchier.
A short shifter isn't really for performance. It's more for "shift feel." With a decent made short shifter you'll never grind as long as the linkage is properly adjusted. My Skunk2 never grinds my ancient cable tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyrx »</TD></TR><TR><TD CLASS="quote">make sure it is a dual bend they shift alot better.</TD></TR></TABLE>
And make sure you get a round wheel, they roll better
The bends make no difference, the ones with the bend are originaly made for the integras cause of the cupholders but you can use them if you want.
I can not possibly think of one con to a short shifter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatchback »</TD></TR><TR><TD CLASS="quote">yea just dont buy an autozone one...haha 2 of my friends have broken 3 of them...well one friend broke 2 of them and the other broke one</TD></TR></TABLE>
Try and get a solid one.
But just so you know any shifter can break, I killed a OEM shifter.
Sometimes I dont know my own strength
Try and get a solid one.But just so you know any shifter can break, I killed a OEM shifter.
get a 94-01 integra shifter! they feel the best and are OEM. The shift feels perfect in an ED and sits your shift **** a lot lower and feels great...dont have to worry about synchros either
keep factory shifter, i have gone through 2 shifters (ebay and dc sports) both broke. go with a 00-01 integra type r modified to fit. nicest feel, short, and strongest youll get with out destroying your cd deck, tranny, and hand
got mine for $80 brand new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">
i can. i can shift a stock shifter fast enough to grind gears why do i need it to shift any faster
my first car i had a short shifter in, i bent shift fork (trying to force it into gear becasue i was shifting fster than the synchros could do thri job) and ruined synchros.
in the end u are moving the fulcrum, and ytou are going to be using more force to change gears. it feels notchier which is good thing in some peoples books. but after i toasted that one trans i cannot put one on any car i own again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">
I like the feel, the stock shifter feels like I'm rowing a boat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote">
I like the feel, the stock shifter feels like I'm rowing a boat</TD></TR></TABLE>
LOL
LOL
2k1_ITR_0736
31
Jul 20, 2002 08:41 AM
