Boosting 5 pounds, when vtec engages its like...
Old Aug 25, 2004 | 06:14 AM
ThefirstPACT's Avatar
Default Boosting 5 pounds, when vtec engages its like...
i hit a rev limiter. I have a t3/t4 turbo, hks ss bov, tial wg. And only an fmu and vafc for fuel for the moment. Whats your ideas?
Old Aug 25, 2004 | 06:22 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Boosting 5 pounds, when vtec engages its like... (ThefirstPACT)
So what you are saying is that your rev limiter kicks in at 5500?
You have a check valve installed? Has it always been like this or did it just start happening?
Old Aug 25, 2004 | 06:32 AM
Default Re: Boosting 5 pounds, when vtec engages its like... (si2die4)
sometimes it will go away. I do have the check valves for the map. I can change my vtec engagement and the the "limiter" thing kicks in again!
Old Aug 25, 2004 | 07:30 AM
Honda_Tengoku's Avatar
whats your spark plug gap. Sounds like u are blowing the flame kernal out on the plugs. I believe people say to lower the plug gap to .028 to .030. good luck.
Old Aug 25, 2004 | 07:36 AM
HybridKOOP's Avatar
Default Re: Boosting 5 pounds, when vtec engages its like... (Honda_Tengoku)
Yup, check plug gap, and make sure you have gas-o-line to keep your A/F's safe.
Old Aug 25, 2004 | 08:13 AM
i my honda
Global Mod
2 step colder plugs gapped to .030
It sounds like your vtec controller is miswired or something. Could be a bad ground maybe. Do you have a CEL? If so check it and get back with us! If not than it is 100% you VAFC wiring
Old Aug 25, 2004 | 08:38 AM
warrick's Avatar
make sure you're not leaning/running too rich. have a friend drive behind you and look for black smoke..
I suggest getting bigger injectors, throwing the missing link away, and running 10 pounds, dyno tuned with the vafc.
Old Aug 25, 2004 | 10:46 AM
BoostedBildo's Avatar
Default Re: Boosting 5 pounds, when vtec engages its like... (warrick)
vtec controllers are the devil, just set your vtec and ditch the gadget!
hyracer
Aug 4, 2011 05:24 AM
southernSCHEME
70
Oct 19, 2010 06:58 AM
JDM Lyfestyle
Mar 18, 2009 08:57 AM
curtisb16
Jul 26, 2007 07:01 AM
