Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Time to replace the Victoracers...
Old Aug 25, 2004 | 05:09 AM
Chris F's Avatar
Default Time to replace the Victoracers...
I'm looking to replace my victoracers on my ITR. I've been running 225/50 in front, 205/50 in rear and been happy for HPDE's and autocross.
I had the BFG G-Force before, I went through them really quickly (probably driving style!) so I probably won't get them again. Hoosiers are kinda expensive and I've heard they don't wear friendly.
Victoracers aren't in stock at Tire Rack. I might try looking at Discount Tire too.
I saw a thread about the Avon tires, anyone using them yet? How well do they stick/wear?
So I guess I'm down to Kuhmo Ecsta V700, Victoracer if I can find them, or the Avon tires.
Also, should I ditch the 225's in front?
Thanks,
Chris
Old Aug 25, 2004 | 05:11 AM
.RJ's Avatar
.RJ
Default Re: Time to replace the Victoracers... (ccfries)
Toyos - I'd run 205/50's just for ease of rotating.
Old Aug 25, 2004 | 06:30 AM
L8ApexH22's Avatar
Stay away from the Ecsta V700...they suck *****.
Discount has always been able to get Victos for me; give tham a shot. My local store matches TireRack's pricing, as well...
Old Aug 25, 2004 | 06:36 AM
Chris F's Avatar
Default Re: Time to replace the Victoracers... (.RJ)
I figured you would have recommended the victoracers you have for sale in your sig
Proxes RA-1, eh? I hadn't considered those. How do they compare with the victoracers in terms of wear and grip?
Thanks .RJ.
-Chris
Old Aug 25, 2004 | 06:41 AM
.RJ's Avatar
.RJ
the RA-1's wont be as sticky for autocross use (need a bit of heat to get them warmed up) but will wear much better for track use.
Another good choice is the hard compound Yok A032's but they are $$$ new
Chris F's Avatar
Default Re: Time to replace the Victoracers... (L8ApexH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L8ApexH22 &raquo;</TD></TR><TR><TD CLASS="quote">Stay away from the Ecsta V700...they suck *****.
Is that the technical term for that? I didn't notice that on the Tirerack website
Old Aug 25, 2004 | 06:48 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Another good choice is the hard compound Yok A032's but they are $$$ new </TD></TR></TABLE>
I ran those for an auto-X while on a different car. Those tires are LOUD when they have full tread depth. Not very sticky for autoX... but that's not my primary concern anymore. Yeah, they're a little expensive too. Hmm!
Old Aug 25, 2004 | 06:52 AM
.RJ's Avatar
.RJ
If you wanted something that sticks well for autox and is reasonably durable on track I think the Victos are a good choice - and they're relatively cheap.
Old Aug 25, 2004 | 06:56 AM
Bull's Avatar
Can someone give me a cost comparison between the Victoracers, RA-1 and the AO32R (all in 205/50/15)?
Old Aug 25, 2004 | 06:57 AM
sackdz's Avatar
I used 225/45-15 Avon Tech R's at MidOhio. They are way stickier then the RA-1's and take more heat before they go crappy. I haven't been on anything except RA-1's tho for a year and a half so I can't compare to Victoracers.
Old Aug 25, 2004 | 07:16 AM
Sean O'Gorman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">
Is that the technical term for that? I didn't notice that on the Tirerack website </TD></TR></TABLE>
Then you haven't gone through the customer reviews for them. Not a very popular track tire it seems.
The Victos would seem to be a good choice, but I've been told that Kumho is way backordered and Tire Rack wont have any new ones for quite awhile.
I heard the Avons are a good tire but do not work well on camber-challenged cars, so keep that in mind.
Old Aug 25, 2004 | 07:19 AM
SPiFF's Avatar
Default Re: Time to replace the Victoracers... (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">I used 225/45-15 Avon Tech R's at MidOhio. They are way stickier then the RA-1's and take more heat before they go crappy. </TD></TR></TABLE>
How do you think these tyres will wear?
Old Aug 25, 2004 | 03:56 PM
Mohudsolo's Avatar
Default Re: Time to replace the Victoracers... (SPiFF)
I got a set of Hoosier Spec Miata R3S04's in 205/50/15 this year. So far they have worked well on track. I have not tried autocross on them. They are supposed to be a harder version of the tire. They are a bit cheaper too. Tire Rack will not admit to having ever heard of them. I got mine through Phil's Tire Service. I only have a few days at Watkins Glen with them but the wear was fairly light. Probably more wear than the Victors but not way more and really good grip and overall feel.
Old Aug 25, 2004 | 04:02 PM
bb6h22a's Avatar
Default Re: Time to replace the Victoracers... (Bull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bull &raquo;</TD></TR><TR><TD CLASS="quote">Can someone give me a cost comparison between the Victoracers, RA-1 and the AO32R (all in 205/50/15)?</TD></TR></TABLE>
Victo is the cheapest
RA - 1 & A032 R are about the same cost wise, but the RA1 is the quicker of the two; the A032R, however, will last longer.
Old Aug 25, 2004 | 04:03 PM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">I used 225/45-15 Avon Tech R's at MidOhio. They are way stickier then the RA-1's and take more heat before they go crappy. I haven't been on anything except RA-1's tho for a year and a half so I can't compare to Victoracers. </TD></TR></TABLE>
How much camber are running?
What was the wear like, and based on your experience, how many events could you see these tire weathering?
Modified by bb6h22a at 5:46 PM 8/25/2004
Old Aug 25, 2004 | 04:21 PM
sackdz's Avatar
Default Re: Time to replace the Victoracers... (bb6h22a)
around 3* in front and temps were even. im not sure about the wear id have to check
Old Aug 25, 2004 | 06:36 PM
swift-speed's Avatar
I sell the Toyo RA1. 205/50-15 shaved to 4/32 are $139.95 ea. These will outlast any other R compound tire. These are the perfect tire for track days. Hoosiers and Kuhmo's are stickier for autocross in the "A" compound. But for track days the Toyo will last 3-4 times longer.
As for the comment on the Hoosieer SM compound, fortunately for me, The Tire Rack is not allowed to sell that tire. Only dealers who provide Trackside service are allowed. So, they may not know what they are, but more than likely they are just trying to sell the regular R3S04 compound which is about $35 more than the SM compound. The RA1 still outlasts the SM compound as well.
One other word, the Avon Tech R is an Autocross tire ONLY! We ran test with them agains the Hoosier and they were complete toast, cords and wires showing in 10 laps. That is why there is no speed rating on them as well.
One last word on the RA1, as it wears and gets "balder" it gets faster without getting greasy. So even if you choose to not shave the tire, over time the tire will get faster. Try that with any other brand.
http://www.frisbyracetire.com
PatrickGSR94
Feb 19, 2011 06:37 PM
uncleben
Jan 18, 2006 08:23 PM
civickidd99
40
Jun 5, 2003 06:54 PM
NightHawkC5
Feb 22, 2003 01:59 PM
01YellowITR
Apr 8, 2002 04:51 PM
