NX Express fogger nozzle location idea??
Old Aug 24, 2004 | 11:37 PM
asubennett's Avatar
Default NX Express fogger nozzle location idea??
This may be the worst idea anyone has ever had but I am curious none the less.
First question is.... How does the spray pattern of a NX single fogger nozzle look?
Second question is..... What would happen in terms of distribution if the the nozzle was placed exactly center on the top of a Skunk 2 manifold. so that it was located between cylinders 3 and 2.
Third Question...... Is the spray pattern wide enough to cover all four cylinders or would it create even worse distribution problems than having it located before the throttle body?
Thanks for any insight.
Old Aug 25, 2004 | 05:41 PM
asubennett's Avatar
Default Re: NX Express fogger nozzle location idea?? (asubennett)
Can anybody help with this one?
Old Aug 25, 2004 | 05:48 PM
Freemantle's Avatar
You will get lousy distribution. The runners for cylinders 3 and 4 would get almost nothing. A shop owner I knew from Michigan ran that setup on his Talon to engine failure. The distribution was so bad that nitrous pooled in the #1 and 2 runners. After he rebuilt that engine, he ran his system through a manifold tapped for an additional injector setup, but he ran wet solenoids where the fuel injectors would be (1 per runner). Now he makes 640 to all for wheels on his Direct Port/Turbo setup.
Old Aug 25, 2004 | 05:58 PM
asubennett's Avatar
Default Re: NX Express fogger nozzle location idea?? (Freemantle)
Thanks, that is sort of what I was anticipating. Anyone else share the same sentiments.
MugenSpeclNY
Jan 23, 2014 12:29 PM
lude98SH
10
Dec 15, 2008 02:19 PM
wushubrian
Dec 11, 2005 08:27 PM
.Noah Fecks
Feb 6, 2005 10:37 AM
Nick_Jr
Mar 10, 2004 02:55 PM
