Pinstrip removal
Old Aug 24, 2004 | 04:25 PM
toadolson's Avatar
Default Pinstrip removal
This is the only thread i found:
https://honda-tech.com/zerothread?id=406295
Wanted to know if anyone has used one of those pinstripe removal puck that you put into a drill. The car is a 94 civic coupe and the front has been recently painted. This pinstripe come off very easily. Now the door and rear are the OEM paint and pinstripe from the dealer. Now i know about pinstripe setting into the paint but this happen from from fresh paint from auto repair. From the factory they don't pinstripe cars, this is done at the dealers. Will one of these pucks work on 10 year old pinstripe or what my best line of defense. Thanks
Old Aug 24, 2004 | 05:22 PM
eL's Avatar
eL
Today me and a "friend" of mine took off a pin stripe using a a Scunci Steamer... thats all it was good for.
Came off fairly easy using the steamer... which was returned to pepboys immediately after... its worthless for anything besides what we used it for.
Old Aug 24, 2004 | 05:56 PM
Team 4's Avatar
Default Re: (eL)
I used a sore thumb and Goo-Gone dammit!
Old Aug 24, 2004 | 06:01 PM
japspecjohn's Avatar
Default Re: (Team 4)
I picked away
Old Aug 24, 2004 | 06:13 PM
cd5_2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team 4 &raquo;</TD></TR><TR><TD CLASS="quote">I used a sore thumb and Goo-Gone dammit! </TD></TR></TABLE>
ha ha ha..ive done this method plenty of times...
very time consuming and frustrating...
Old Aug 24, 2004 | 06:18 PM
Team 4's Avatar
Default Re: (cd_5TUNR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd_5TUNR &raquo;</TD></TR><TR><TD CLASS="quote">
very time consuming and frustrating... </TD></TR></TABLE>
I had 8 hours to kill at work, so I figured I get something constructive done!
Old Aug 24, 2004 | 06:29 PM
gamby's Avatar
Default Re: Pinstrip removal (toadolson)
Wow. Maybe I was lucky, but I used a hairdryer to soften the stripe up and peeled the whole thing off in about 15 minutes.
I think you guys might be overthinking the issue.
Old Aug 24, 2004 | 08:35 PM
bucketheadCRX's Avatar
Default Re: Pinstrip removal (gamby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamby &raquo;</TD></TR><TR><TD CLASS="quote">Wow. Maybe I was lucky, but I used a hairdryer to soften the stripe up and peeled the whole thing off in about 15 minutes.
I think you guys might be overthinking the issue. </TD></TR></TABLE>
well..really depends on how old the car is..my 89 crx had those nice 15 year old encrusted pinstripes that..did finally come off after much frustating..peel..break..peel..break..and then..goo-gone..try everything mentioned in that earlier thread..hair dryer..razor blade(very carefully of course)to get the stripe started peeling..again and again..grrrr slow but steady pulling on the stripe(because they love to keep breaking)..good luck and enjoy your stripe-free car
Old Aug 27, 2004 | 08:21 AM
gamby's Avatar
Default Re: Pinstrip removal (buckethead36)
On my 12 year old CX, I found that the hairdryer stopped the striping from breaking. It softened it up quite a bit.
Old Aug 27, 2004 | 08:42 AM
.ShawnD.'s Avatar
i used an eraser wheel that you put in a drill i dont know if thats the same thing but it works fast !!
Old Aug 27, 2004 | 09:02 AM
Code Blue's Avatar
Default Re: (.:s h a w n D:.)
be very careful with the rubber wheels, they get hot very quickly and can burn through your clear coat and paint in a second, try lightly heating it up with a heatgun and peeling it off, no damage can really happen using that method
Old Aug 27, 2004 | 11:40 AM
wisjdmhonda's Avatar
Default Re: (eL)
use really hot water thats what we use at honda. im a detailer
srok1
Paint and Body
29
Oct 20, 2009 12:38 PM
lilj95
22
Jul 26, 2009 08:51 PM
KaoSyN
Feb 28, 2007 09:54 PM
k-man
Oct 25, 2004 03:47 PM
j_ambrose
11
Jan 14, 2003 07:27 PM
