itr sway bar question. again
i know this topic has been covered before and i already did a search for it but i didn't find the answer i needed so..
i have a 92 hatch CX i was wondering will the itr lower control arm fit on my car? cause i thought the shocks mount different on the itr lca. if it doesn't fit i will get the gsr lca those fit perfectly right? anyways which endlinks do i have to use for the the gsr lca, the itr endlinks or the gsr endlinks? also which prothane kit do i need to get? i know i need the 7/8" one but there are two different ones the Choice of brackets: 1-1/4" H x 3-5/8" W or; 1-5/8" H x 4-1/4" W.
http://www.jcwhitney.com/item.jhtml?ITEMID=7504
thanks for any info
thanks for any info
The ITR LCA's will "fit", but that's if you run ITR shocks. Just run any 3G Integra LCA's (or 5G Civics LCA w/swaybar mounting holes) and you'll be fine. GS-R and ITR end-links are the same. Go to a junk yard and buy used bar that comes with them. It'll save you a bundle. Get the 1-1/4" X 3-5/8" Prothane brackets.
-Wil
BeaksProducts@hotmail.com
-Wil
mister2racer
Aug 4, 2003 12:28 AM
comptechgsr
Sep 15, 2002 12:00 AM
