Oil problem.
Old Aug 24, 2004 | 12:07 PM
Carbon_Lude98's Avatar
Default Oil problem.
ok i have a 97 base prelude h22a4. 70,000 miles
i just bought it like mabey 2 months ago..had the oil changed two weeks ago..probly drove it about 300-500 miles. it already is down to half on the dip stick.
i had it checked 4 leaks, they said no signs of leaks ever thing is clean..
whats wrong...i know it should not be burning oil this fast should it?
please help!
Old Aug 24, 2004 | 12:19 PM
PreludeMTX's Avatar
Default Re: Oil problem. (Carbon_Lude98)
Probably forgot to fill the oil filter with oil during last oil change. Have someone give your gas a few rev's and stand in the back looking for any smoke out your exhaust. If it's clean don't worry about it. Add a half quart and check it in a week. I bet it will be fine.
Old Aug 24, 2004 | 12:37 PM
no smoke..but i do notice little black specs on my bumper..looks like carbon...but my b16 did that so i quess thats cool..
i'll just add a quart...
thanks alot.
Old Aug 24, 2004 | 01:31 PM
GSRnold's Avatar
Default Re: Oil problem. (PreludeMTX)
Are you supposed to fill the oil filter with oil during an oil change?
Old Aug 25, 2004 | 04:59 AM
PreludeMTX's Avatar
Default Re: Oil problem. (GSRnold)
Yea, always put some oil in the filter before you screw it in.. It's not the end of the world if you dont, but its better overall for the pump and what not..
Old Aug 25, 2004 | 07:26 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeMTX &raquo;</TD></TR><TR><TD CLASS="quote">Yea, always put some oil in the filter before you screw it in.. It's not the end of the world if you dont, but its better overall for the pump and what not..</TD></TR></TABLE>
wow, that's a new one to me
Old Aug 25, 2004 | 08:42 AM
PreludeMTX's Avatar
Default Re: Oil problem. (SKDRCR)
I worked at a shop where i learned that technique..fill the filter with a little bit of oil, smear a little oil on the filter rubber gasket, and slap it in.. Has anyone heard of this or is it pointless?
Old Aug 25, 2004 | 10:01 AM
SKDRCR's Avatar
i know about putting oil on the seal
but putting oil in the filter b4 you slap it in would just
cause a mess, but to each their own i guess.
Old Aug 25, 2004 | 10:42 AM
kellyk75's Avatar
You don't have to fill up the filter...... the pump will do that for you..... and it doesn't hurt it. As for the oil on the seal.... that is legit.
Back to the prob at hand...... if you vtec alot (new car to you..... I am sure you do:D), the vtec is designed to burn a little oil. If you keep it under vtec you will burn alot less.
Old Aug 25, 2004 | 11:14 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carbon_Lude98 &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a 97 base prelude h22a4. 70,000 miles
please help!</TD></TR></TABLE>
wat oil do you use...and number?
5-30, 10-30, or 10-40?
i would expect the 5-30 to burn little more?
and about the filter...dont **** around with it and add oil in...do it the HONDA's way...dont add any oil in the filter please....after oil change let it running for 5min (to operating T) then turn it off..go fine soem junk foods, take a pee, restroom, waaste ur hands and **** or watch the new for like 10min and there...go back out check ur oil stick...
stevanrk
Aug 31, 2008 05:09 PM
b18teggy
Jun 28, 2008 03:41 PM
JimmyM86
Honda Civic (2001 - 2005)
Jul 13, 2007 12:13 PM
Puki
May 19, 2003 11:56 AM
RAB
Aug 25, 2002 02:32 PM
