Timing....
Me = 86 Si... I put a new headgasket in her and i think the timing could be off slightly doesnt run quite right until after 3.5K, sputtery and jumpy idle stalling slightly in lower rpms... i know im a noob and you all know this but how do i advance or retard the timing using the distributer. any help will be greatly appreciated
If the timing belt is off, you ceratinly won't be able to reset the timing by simply moving the distributor. The valve timing has to be correctly synchronized with the piston timing or the result will be what you have....
Modified by cmrvi1 at 12:16 AM 8/26/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmrvi1 »</TD></TR><TR><TD CLASS="quote">Is the timing belt is off, you ceratinly won't be able to reset the timing by simply moving the distributor. The valve timing has to be correctly synchronized with the piston timing or the result will be what you have.... </TD></TR></TABLE> very well put, you should also put a timming light to it and see where the timming marks are.
i to have a zc and changed the head gasket and my car is doing the exact same thing then i tried to fix the timing but now it dosent even turn over at all just keep whinning like a baby
when i changed my timing my friend who knows more about engines than me that helped me do it said " i doubt it'll even crank cause i think the timing is off 1 tooth" but being impatient i decided to try and see if it would crank anyways it didnt even turn over twice before it fired right up, smoked like an *** for a couple seconds but eventually stopped, i thin kit smoked cause there was some transmission fluid on the pistons from where i was cleaning them but anyways its been like that since, 4 months ago.. i beat a 00' eclipse rs with the timing off.. lol
at first mine fired right up but when i turned of off and on again a few times by the 4th time it wouldnt start and it was smoking like a chiminey i was thinking that maybe i didnt torque down the head bolts right but maybe its because of the leftover coolant like yours hopfully it is .
luvs2spooge
May 18, 2007 05:42 PM
CIVIC96DXcp
Apr 19, 2005 07:47 PM
dr_latino999
Dec 2, 2004 09:55 PM
